How To Fix an iPhone 17 Air That Randomly Restarts
Device iPhone 17 Air
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 17 Air to randomly restart every few minutes. For the iPhone 17 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 17 Air series are:
  • Power Button Flex - This is the flex that connects the power button to the logic board.
  • Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged by water/drops or when someone has replaced the port with a bad/aftermarket one.
  • After a charging port replacement, the iPhone will restart every 3 minutes.
  • After a power button replacement, the iPhone will restart every 3 minutes.
iPhone 15 - FPCs to Inspect for 3 Min Restart
For this model, look for where it says "SMC PANIC - ASSERTION FAILED" ... "Sensor Array" .. "23...."
If you see:
  • 0x200000 - it's the Wireless Charging Flex (Back Glass)
    • Could be a sandwich issue
iPhone 15 - Charging Port Flex
  • 0x80000 - it's the Charging Port Flex and/or Air Pressure Sensor
    • Make sure the Air Pressure Sensor is plugged in
    • Test with OEM or Premium. Aftermarket parts have a high defect rate
  • Bad or damaged flex
