Cant Draw Diagonal Lines After Screen Replacement
Revision as of 21:06, 14 September 2025 by Tiago199988 (talk | contribs)
Device IPad Pro 12.9 3rd Gen
Affects part(s) Display
Needs equipment JCID V1S or JCID 1Vs Pro
Difficulty
Type
After replacing the screen the Apple pencil can not be used to draw diagonal lines.
The Solution is simple however we need a special tool made by JC.
You can use the JC V1SE or the JC V1S Pro.
Final Testing
After assembling the console, ensure every function is working as expected.
If you replaced the Retimer IC mare sure the console is able to output image in 4K.
