RepairWiki:Guidelines
Revision as of 16:08, 12 November 2023 by ASRepairs (talk | contribs)
Welcome!
Welcome to the Repair Wiki! This platform is designed to collect and organize information on repairing electronic devices in one place. Before contributing to the Wiki, there are a few important things to keep in mind.
Wiki Structure
Repair wiki structure
  1. Manufacturer: stores links to every device made by that manufacturer and every repair guide published for those devices
  2. Device: stores reference information for the device such as pictures, voltage and resistance measurements etc. to act like a working device to compare the broken one to along with guides created for that specific device.
  3. Repair guide: documentation of single problem and its solution(s)
  4. Explanatory: can be used to document and explain how a device works or how to diagnose a problem
Manufacturer pages
Device pages
Filling the page is as simple as uploading relevant photos to the appropriate sections, If there are external sources you want to link, making sure the content you are linking is archived is important. Here's how
  • Pictures of the PCB
  • Power up sequence (If applicable)
  • Diagrams/schematics of the important parts of the device
  • Working state measurements of:
    • resistances and voltage measurements for various power rails
    • diode mode readings for important components, circuits, and connectors
Example device page
Repair Guide pages
When done, save the page then click Edit semantics button at the top and fill in the information about this guide. This step is very important to assign your guide to the appropriate device(s) and make it easier to find. Repair guides are stubs by default! If you believe the guide you wrote has little to no improvements left then you can remove the stub tag either by clicking on it in visual editor and then delete or by removing the ''{{stub}}'' in source editor.
  • Affected parts: the parts which the guide is intending to repair/fix. E.g. Motherboard, Display assembly, Speaker, Touch sensor.
  • Equipment needed: input everything you used to repair the problem from tools used to open the device to tools used to replace the broken/faulty parts.
  • Type: choose the type of repair guide
  • Difficulty:
    • Easy: only for part replacement where the parts can be easily obtained and there is little to no risk of breaking the device while trying to replace it
    • Medium: for part replacement if the parts can't be easily obtained and there is mild risk of breaking the device while opening/replacing
    • Hard: anything that includes soldering
    • Specialist: BGA reworking
Example repair guide
Explanatory pages
The only attributes for explanatory pages are the topic subject, and the type.
Example explanatory page
New Page
Legend
Styling used to keep repair.wiki's infrastructure consistent and understandable:
  • header - company
  • underlined - has a repair page
  • Italicized - range (a.k.a. - group of series)
  • bold - series (a.k.a. - group of devices)
  • neither - device (a.k.a. - electronic model)
Create
Create a new page!
Move
If a page has an incorrect title, you can move it:
  1. Mouseover the More tab in the top right and click Move.
  2. Give the page a New title and click Move page.
  3. For normal pages, don't change the default namespace (Main).
  4. Note that if you move a category page, pages belonging to it will need to be recategorized manually.
Delete
Other options:
  • If you don't want to have it truly deleted (to come back later to work on or archive it), or can't wait, then give the page a title that's not in use nor will be found. Just be sure to add the link of the page in the discussion tab of the place it got moved from, so people know it's still there if it was decided on being moved.
  • You can also add it to the Stub category by inserting {{Stub}} at the top of the page too for the off-chance someone else can grow it. Visit Stub Pages to help out those with the most need of contribution.
Minor changes
Table of Contents
Section level headers
From the Edit Source tab:
Section headers are added by using equal signs. Each indentation to a new level gets an extra equals sign surrounding the name (i.e. Level 2 gets 2 equals signs on each side, Level 3 gets 3, etc.).
Level 1 headers are reserved for the title and should not be used (i.e. =Example=).
==Level 2 header==
==Level 3 header==
Text
From the Edit tab:
Major Changes
Categories
Source Editor
Visual Editor
Notes:
  • Once you save a category, changing it becomes cumbersome, so make sure you get it right. New subcategories can be added however.
  • Often a category will have a separate gateway article with links to specific products. Check the URL to make sure you're on the right page.
    • If a link to your page doesn't show up, try clearing the cache:
MediaWiki
This wiki uses MediaWiki Formatting, which is also used on Wikipedia. (Also known as Wikitext - there's a link to general help about MediaWiki / Formatting in the sidebar.).
Page Formatting
Links & Citations
Internal Links (Repair Wiki)
[[Main Page]]
[[Standards|Standards page]]
Result:
Main Page
Standards page
If the link is red, either the link is wrong, or the page doesn't exist yet.
However if you want a page to redirect to another page, you can use the following:
#REDIRECT [[Target Page]]
External Links (other websites)
Consider archiving your links to avoid link rot.
[https://www.gofundme.com/f/lets-get-right-to-repair-passed Right to Repair fundraiser]
Result:
From the Edit tab:
After highlighting the text to use, use the hyperlink symbol or CTRL + K to add a link.
Citations
To transform an external link into a citation, enclose it in <ref>URL</ref> tags:
Donate to the GoFundMe<ref>https://www.gofundme.com/f/lets-get-right-to-repair-passed Right to Repair fundraiser</ref>
If you want control over where the references list appears on the page use:
{{Reflist}}
Result:
Donate to the GoFundMe[1]
Italic & Bold Font
Don't be scared to use bolded text frequently in your articles, such as highlighting crucial steps of the repair process or safety warnings. It helps the reader find what they're looking for faster.
Source Editor:
* ''italic text''
* '''bold text'''
** '''''bold italic text'''''
Result:
  • italic text
  • bold text
    • bold italic text
Line breaks
line break arrow
Arrows in the editor indicate a single line break. Characters following line breaks will be inserted on the next line.
You can add them in the source editor by typing <br>
Put line breaks on a new line, so people know they're there.
Use {{clear}} for line breaking all elements, including images.
In-line Tabs
Source editor, for 3 tabs:
{{#tag:tabber|
Tab 1=
one
Tab 2=
two
Tab 3=
three
Results:
one
two
three
Uploading & Embedding Files
Click Upload File in the sidebar to upload files.
Once uploaded, insert either of the following at the top of the page:
{{File|FileName.png|Fig. 1: File Caption}} or [[File:FileName.png|right|thumb|350px|<center>'''Fig. 1: File Caption'''</center>]]
Example:
Fig. 1: Rossmann Group logo
Make sure to reference the image in the solution text, ie. "See Fig. 1".
You can search for images in the public domain here.
Templates
  • You can create your own template by typing the name of it after https://repair.wiki/w/Template:
  • Find what's already created here Category:Formatting templates. Boilerplate templates are portions of information that get copied/pasted. If you edit the original, all the copies will change automatically.
Transclusion
You can include a page inside another page with {{:Page name}}.
Make sure to use <onlyinclude>text</onlyinclude> to not duplicate too much content (search engines don't like it).
Note:
Make sure the page or Template you're transcluding has its categories inside noinclude tags: <noinclude>[[Category:IPhone]]</noinclude>
if you want to link to a category instead, colon symbol in front of it: [[:Category:Product Repair Guides]]
Code text:
A highlighted blue box around text that's inside it.
Source editor: type in <code>highlight word</code>
Result:
highlight word
Visual editor: copy/paste from text that already has it.
Warning:
Watch out for writing before and after the box, because they might get mixed into the box itself, when it shouldn't.
Suggestions
If you have suggestions for how to improve the wiki, you can leave them on Talk:Repair Wiki
Talk Pages / Discussion
Every page has a Talk Page associated with it.
Click on Discussion in the top left to leave a comment on it, then add ~~~~ to insert a user signature, like so: Patrolin (talk) 15:21, 24 April 2021 (PDT)
It is probably easier to just use the Discord, but it's a good use for leaving notice board-like notes.
Responses
When responding to someone in the talk pages, do it on a new line and prefix your message with : to give it indentation.
This is the OP speaking. Patrolin (talk) 02:43, 5 May 2021 (PDT)
This is a response to OP. Karar (talk) 02:57, 5 May 2021 (PDT)
Here I've used double colon punctuation :: to respond to the message above. Patrolin (talk) 03:00, 5 May 2021 (PDT)
Another response to OP. Karar (talk) 02:57, 5 May 2021 (PDT)
Your work
  • Mentioning copyrighted materials is at times unavoidable; sometimes someone already wrote out the solution or the reader wants more detail. Refer to the "Links & Citations" section under the "Formatting" tab to properly cite others' work.
  • If you make a new page or category on the Repair Wiki, you don't need to ask anyone for permission. You can even give yourself or someone else credit by inserting {{Credit|Name}}
  • All content on the Repair Wiki is for public use. You can freely download pages for your own use or for sharing with others using Special:Export.
Proprietary Material
  • Examples: patented schematics, instruction manual PDFs, other people's images, plagiarized problems/solutions from online articles etc.
  • Material that is not your own or available for use under laws (such as fair use), licenses (i.e. open source), and copyrights (like public domain or creative commons) shouldn't be posted without permission. If permission is granted, then that should be stated next to the proprietary material, so that it's made known and can be verified by the grantor.
  • Anything that puts (or is at risk of putting) the Repair Wiki at risk of being litigated against and taken down shouldn't be posted.
Contents
