Documentation for this module may be created at Module:Infobox/doc
local p = {} local args = {} local origArgs = {} local root local empty_row_categories = {} local category_in_empty_row_pattern = '%[%[%s*[Cc][Aa][Tt][Ee][Gg][Oo][Rr][Yy]%s*:[^]]*]]' local has_rows = false local lists = { plainlist_t = { patterns = { '^plainlist$', '%splainlist$', '^plainlist%s', '%splainlist%s' }, found = false, styles = 'Plainlist/styles.css' }, hlist_t = { patterns = { '^hlist$', '%shlist$', '^hlist%s', '%shlist%s' }, found = false, styles = 'Hlist/styles.css' } } local function has_list_class(args_to_check) for _, list in pairs(lists) do if not list.found then for _, arg in pairs(args_to_check) do for _, pattern in ipairs(list.patterns) do if mw.ustring.find(arg or '', pattern) then list.found = true break end end if list.found then break end end end end end local function fixChildBoxes(sval, tt) local function notempty( s ) return s and s:match( '%S' ) end if notempty(sval) then local marker = '<span class=special_infobox_marker>' local s = sval -- start moving templatestyles and categories inside of table rows local slast = '' while slast ~= s do slast = s s = mw.ustring.gsub(s, '(</[Tt][Rr]%s*>%s*)(%[%[%s*[Cc][Aa][Tt][Ee][Gg][Oo][Rr][Yy]%s*:[^]]*%]%])', '%2%1') s = mw.ustring.gsub(s, '(</[Tt][Rr]%s*>%s*)(\127[^\127]*UNIQ%-%-templatestyles%-%x+%-QINU[^\127]*\127)', '%2%1') end -- end moving templatestyles and categories inside of table rows s = mw.ustring.gsub(s, '(<%s*[Tt][Rr])', marker .. '%1') s = mw.ustring.gsub(s, '(</[Tt][Rr]%s*>)', '%1' .. marker) if s:match(marker) then s = mw.ustring.gsub(s, marker .. '%s*' .. marker, '') s = mw.ustring.gsub(s, '([\r\n]|-[^\r\n]*[\r\n])%s*' .. marker, '%1') s = mw.ustring.gsub(s, marker .. '%s*([\r\n]|-)', '%1') s = mw.ustring.gsub(s, '(</[Cc][Aa][Pp][Tt][Ii][Oo][Nn]%s*>%s*)' .. marker, '%1') s = mw.ustring.gsub(s, '(<%s*[Tt][Aa][Bb][Ll][Ee][^<>]*>%s*)' .. marker, '%1') s = mw.ustring.gsub(s, '^(%{|[^\r\n]*[\r\n]%s*)' .. marker, '%1') s = mw.ustring.gsub(s, '([\r\n]%{|[^\r\n]*[\r\n]%s*)' .. marker, '%1') s = mw.ustring.gsub(s, marker .. '(%s*</[Tt][Aa][Bb][Ll][Ee]%s*>)', '%1') s = mw.ustring.gsub(s, marker .. '(%s*\n|%})', '%1') end if s:match(marker) then local subcells = mw.text.split(s, marker) s = '' for k = 1, #subcells do if k == 1 then s = s .. subcells[k] .. '</' .. tt .. '></tr>' elseif k == #subcells then local rowstyle = ' style="display:none"' if notempty(subcells[k]) then rowstyle = '' end s = s .. '<tr' .. rowstyle ..'><' .. tt .. ' colspan=2>\n' .. subcells[k] elseif notempty(subcells[k]) then if (k % 2) == 0 then s = s .. subcells[k] else s = s .. '<tr><' .. tt .. ' colspan=2>\n' .. subcells[k] .. '</' .. tt .. '></tr>' end end end end -- the next two lines add a newline at the end of lists for the PHP parser -- [[Special:Diff/849054481]] -- remove when [[:phab:T191516]] is fixed or OBE s = mw.ustring.gsub(s, '([\r\n][%*#;:][^\r\n]*)$', '%1\n') s = mw.ustring.gsub(s, '^([%*#;:][^\r\n]*)$', '%1\n') s = mw.ustring.gsub(s, '^([%*#;:])', '\n%1') s = mw.ustring.gsub(s, '^(%{%|)', '\n%1') return s else return sval end end -- Cleans empty tables local function cleanInfobox() root = tostring(root) if has_rows == false then root = mw.ustring.gsub(root, '<table[^<>]*>%s*</table>', '') end end -- Returns the union of the values of two tables, as a sequence. local function union(t1, t2) local vals = {} for k, v in pairs(t1) do vals[v] = true end for k, v in pairs(t2) do vals[v] = true end local ret = {} for k, v in pairs(vals) do table.insert(ret, k) end return ret end -- Returns a table containing the numbers of the arguments that exist -- for the specified prefix. For example, if the prefix was 'data', and -- 'data1', 'data2', and 'data5' exist, it would return {1, 2, 5}. local function getArgNums(prefix) local nums = {} for k, v in pairs(args) do local num = tostring(k):match('^' .. prefix .. '([1-9]%d*)$') if num then table.insert(nums, tonumber(num)) end end table.sort(nums) return nums end -- Adds a row to the infobox, with either a header cell -- or a label/data cell combination. local function addRow(rowArgs) if rowArgs.header and rowArgs.header ~= '_BLANK_' then has_rows = true has_list_class({ rowArgs.rowclass, rowArgs.class, args.headerclass }) root :tag('tr') :addClass(rowArgs.rowclass) :cssText(rowArgs.rowstyle) :tag('th') :attr('colspan', '2') :addClass('infobox-header') :addClass(rowArgs.class) :addClass(args.headerclass) -- @deprecated next; target .infobox-<name> .infobox-header :cssText(args.headerstyle) :cssText(rowArgs.rowcellstyle) :wikitext(fixChildBoxes(rowArgs.header, 'th')) if rowArgs.data then root:wikitext( '[[Category:Pages using infobox templates with ignored data cells]]' ) end elseif rowArgs.data and rowArgs.data:gsub(category_in_empty_row_pattern, ''):match('^%S') then has_rows = true has_list_class({ rowArgs.rowclass, rowArgs.class }) local row = root:tag('tr') row:addClass(rowArgs.rowclass) row:cssText(rowArgs.rowstyle) if rowArgs.label then row :tag('th') :attr('scope', 'row') :addClass('infobox-label') -- @deprecated next; target .infobox-<name> .infobox-label :cssText(args.labelstyle) :cssText(rowArgs.rowcellstyle) :wikitext(rowArgs.label) :done() end local dataCell = row:tag('td') dataCell :attr('colspan', not rowArgs.label and '2' or nil) :addClass(not rowArgs.label and 'infobox-full-data' or 'infobox-data') :addClass(rowArgs.class) -- @deprecated next; target .infobox-<name> .infobox(-full)-data :cssText(rowArgs.datastyle) :cssText(rowArgs.rowcellstyle) :wikitext(fixChildBoxes(rowArgs.data, 'td')) else table.insert(empty_row_categories, rowArgs.data or '') end end local function renderTitle() if not args.title then return end has_rows = true has_list_class({args.titleclass}) root :tag('caption') :addClass('infobox-title') :addClass(args.titleclass) -- @deprecated next; target .infobox-<name> .infobox-title :cssText(args.titlestyle) :wikitext(args.title) end local function renderAboveRow() if not args.above then return end has_rows = true has_list_class({ args.aboveclass }) root :tag('tr') :tag('th') :attr('colspan', '2') :addClass('infobox-above') :addClass(args.aboveclass) -- @deprecated next; target .infobox-<name> .infobox-above :cssText(args.abovestyle) :wikitext(fixChildBoxes(args.above,'th')) end local function renderBelowRow() if not args.below then return end has_rows = true has_list_class({ args.belowclass }) root :tag('tr') :tag('td') :attr('colspan', '2') :addClass('infobox-below') :addClass(args.belowclass) -- @deprecated next; target .infobox-<name> .infobox-below :cssText(args.belowstyle) :wikitext(fixChildBoxes(args.below,'td')) end local function addSubheaderRow(subheaderArgs) if subheaderArgs.data and subheaderArgs.data:gsub(category_in_empty_row_pattern, ''):match('^%S') then has_rows = true has_list_class({ subheaderArgs.rowclass, subheaderArgs.class }) local row = root:tag('tr') row:addClass(subheaderArgs.rowclass) local dataCell = row:tag('td') dataCell :attr('colspan', '2') :addClass('infobox-subheader') :addClass(subheaderArgs.class) :cssText(subheaderArgs.datastyle) :cssText(subheaderArgs.rowcellstyle) :wikitext(fixChildBoxes(subheaderArgs.data, 'td')) else table.insert(empty_row_categories, subheaderArgs.data or '') end end local function renderSubheaders() if args.subheader then args.subheader1 = args.subheader end if args.subheaderrowclass then args.subheaderrowclass1 = args.subheaderrowclass end local subheadernums = getArgNums('subheader') for k, num in ipairs(subheadernums) do addSubheaderRow({ data = args['subheader' .. tostring(num)], -- @deprecated next; target .infobox-<name> .infobox-subheader datastyle = args.subheaderstyle, rowcellstyle = args['subheaderstyle' .. tostring(num)], class = args.subheaderclass, rowclass = args['subheaderrowclass' .. tostring(num)] }) end end local function addImageRow(imageArgs) if imageArgs.data and imageArgs.data:gsub(category_in_empty_row_pattern, ''):match('^%S') then has_rows = true has_list_class({ imageArgs.rowclass, imageArgs.class }) local row = root:tag('tr') row:addClass(imageArgs.rowclass) local dataCell = row:tag('td') dataCell :attr('colspan', '2') :addClass('infobox-image') :addClass(imageArgs.class) :cssText(imageArgs.datastyle) :wikitext(fixChildBoxes(imageArgs.data, 'td')) else table.insert(empty_row_categories, imageArgs.data or '') end end local function renderImages() if args.image then args.image1 = args.image end if args.caption then args.caption1 = args.caption end local imagenums = getArgNums('image') for k, num in ipairs(imagenums) do local caption = args['caption' .. tostring(num)] local data = mw.html.create():wikitext(args['image' .. tostring(num)]) if caption then data :tag('div') :addClass('infobox-caption') -- @deprecated next; target .infobox-<name> .infobox-caption :cssText(args.captionstyle) :wikitext(caption) end addImageRow({ data = tostring(data), -- @deprecated next; target .infobox-<name> .infobox-image datastyle = args.imagestyle, class = args.imageclass, rowclass = args['imagerowclass' .. tostring(num)] }) end end -- When autoheaders are turned on, preprocesses the rows local function preprocessRows() if not args.autoheaders then return end local rownums = union(getArgNums('header'), getArgNums('data')) table.sort(rownums) local lastheader for k, num in ipairs(rownums) do if args['header' .. tostring(num)] then if lastheader then args['header' .. tostring(lastheader)] = nil end lastheader = num elseif args['data' .. tostring(num)] and args['data' .. tostring(num)]:gsub( category_in_empty_row_pattern, '' ):match('^%S') then local data = args['data' .. tostring(num)] if data:gsub(category_in_empty_row_pattern, ''):match('%S') then lastheader = nil end end end if lastheader then args['header' .. tostring(lastheader)] = nil end end -- Gets the union of the header and data argument numbers, -- and renders them all in order local function renderRows() local rownums = union(getArgNums('header'), getArgNums('data')) table.sort(rownums) for k, num in ipairs(rownums) do addRow({ header = args['header' .. tostring(num)], label = args['label' .. tostring(num)], data = args['data' .. tostring(num)], datastyle = args.datastyle, class = args['class' .. tostring(num)], rowclass = args['rowclass' .. tostring(num)], -- @deprecated next; target .infobox-<name> rowclass rowstyle = args['rowstyle' .. tostring(num)], rowcellstyle = args['rowcellstyle' .. tostring(num)] }) end end local function renderNavBar() if not args.name then return end has_rows = true root :tag('tr') :tag('td') :attr('colspan', '2') :addClass('infobox-navbar') :wikitext(require('Module:Navbar')._navbar{ args.name, mini = 1, }) end local function renderItalicTitle() local italicTitle = args['italic title'] and mw.ustring.lower(args['italic title']) if italicTitle == '' or italicTitle == 'force' or italicTitle == 'yes' then root:wikitext(require('Module:Italic title')._main({})) end end -- Categories in otherwise empty rows are collected in empty_row_categories. -- This function adds them to the module output. It is not affected by -- args.decat because this module should not prevent module-external categories -- from rendering. local function renderEmptyRowCategories() for _, s in ipairs(empty_row_categories) do root:wikitext(s) end end -- Render tracking categories. args.decat == turns off tracking categories. local function renderTrackingCategories() if args.decat == 'yes' then return end if args.child == 'yes' then if args.title then root:wikitext( '[[Category:Pages using embedded infobox templates with the title parameter]]' ) end elseif #(getArgNums('data')) == 0 and mw.title.getCurrentTitle().namespace == 0 then root:wikitext('[[Category:Articles using infobox templates with no data rows]]') end end --[=[ Loads the templatestyles for the infobox. TODO: FINISH loading base templatestyles here rather than in MediaWiki:Common.css. There are 4-5000 pages with 'raw' infobox tables. See [[Mediawiki_talk:Common.css/to_do#Infobox]] and/or come help :). When we do this we should clean up the inline CSS below too. Will have to do some bizarre conversion category like with sidebar. ]=] local function loadTemplateStyles() local frame = mw.getCurrentFrame() local hlist_templatestyles = '' if lists.hlist_t.found then hlist_templatestyles = frame:extensionTag{ name = 'templatestyles', args = { src = lists.hlist_t.styles } } end local plainlist_templatestyles = '' if lists.plainlist_t.found then plainlist_templatestyles = frame:extensionTag{ name = 'templatestyles', args = { src = lists.plainlist_t.styles } } end -- See function description local base_templatestyles = frame:extensionTag{ name = 'templatestyles', args = { src = 'Module:Infobox/styles.css' } } local templatestyles = '' if args['templatestyles'] then templatestyles = frame:extensionTag{ name = 'templatestyles', args = { src = args['templatestyles'] } } end local child_templatestyles = '' if args['child templatestyles'] then child_templatestyles = frame:extensionTag{ name = 'templatestyles', args = { src = args['child templatestyles'] } } end local grandchild_templatestyles = '' if args['grandchild templatestyles'] then grandchild_templatestyles = frame:extensionTag{ name = 'templatestyles', args = { src = args['grandchild templatestyles'] } } end return table.concat({ -- hlist -> plainlist -> base is best-effort to preserve old Common.css ordering. -- this ordering is not a guarantee because the rows of interest invoking -- each class may not be on a specific page hlist_templatestyles, plainlist_templatestyles, base_templatestyles, templatestyles, child_templatestyles, grandchild_templatestyles }) end -- common functions between the child and non child cases local function structure_infobox_common() renderSubheaders() renderImages() preprocessRows() renderRows() renderBelowRow() renderNavBar() renderItalicTitle() renderEmptyRowCategories() renderTrackingCategories() cleanInfobox() end -- Specify the overall layout of the infobox, with special settings if the -- infobox is used as a 'child' inside another infobox. local function _infobox() if args.child ~= 'yes' then root = mw.html.create('table') root :addClass(args.subbox == 'yes' and 'infobox-subbox' or 'infobox') :addClass(args.bodyclass) -- @deprecated next; target .infobox-<name> :cssText(args.bodystyle) has_list_class({ args.bodyclass }) renderTitle() renderAboveRow() else root = mw.html.create() root :wikitext(args.title) end structure_infobox_common() return loadTemplateStyles() .. root end -- If the argument exists and isn't blank, add it to the argument table. -- Blank arguments are treated as nil to match the behaviour of ParserFunctions. local function preprocessSingleArg(argName) if origArgs[argName] and origArgs[argName] ~= '' then args[argName] = origArgs[argName] end end -- Assign the parameters with the given prefixes to the args table, in order, in -- batches of the step size specified. This is to prevent references etc. from -- appearing in the wrong order. The prefixTable should be an array containing -- tables, each of which has two possible fields, a "prefix" string and a -- "depend" table. The function always parses parameters containing the "prefix" -- string, but only parses parameters in the "depend" table if the prefix -- parameter is present and non-blank. local function preprocessArgs(prefixTable, step) if type(prefixTable) ~= 'table' then error("Non-table value detected for the prefix table", 2) end if type(step) ~= 'number' then error("Invalid step value detected", 2) end -- Get arguments without a number suffix, and check for bad input. for i,v in ipairs(prefixTable) do if type(v) ~= 'table' or type(v.prefix) ~= "string" or (v.depend and type(v.depend) ~= 'table') then error('Invalid input detected to preprocessArgs prefix table', 2) end preprocessSingleArg(v.prefix) -- Only parse the depend parameter if the prefix parameter is present -- and not blank. if args[v.prefix] and v.depend then for j, dependValue in ipairs(v.depend) do if type(dependValue) ~= 'string' then error('Invalid "depend" parameter value detected in preprocessArgs') end preprocessSingleArg(dependValue) end end end -- Get arguments with number suffixes. local a = 1 -- Counter variable. local moreArgumentsExist = true while moreArgumentsExist == true do moreArgumentsExist = false for i = a, a + step - 1 do for j,v in ipairs(prefixTable) do local prefixArgName = v.prefix .. tostring(i) if origArgs[prefixArgName] then -- Do another loop if any arguments are found, even blank ones. moreArgumentsExist = true preprocessSingleArg(prefixArgName) end -- Process the depend table if the prefix argument is present -- and not blank, or we are processing "prefix1" and "prefix" is -- present and not blank, and if the depend table is present. if v.depend and (args[prefixArgName] or (i == 1 and args[v.prefix])) then for j,dependValue in ipairs(v.depend) do local dependArgName = dependValue .. tostring(i) preprocessSingleArg(dependArgName) end end end end a = a + step end end -- Parse the data parameters in the same order that the old {{infobox}} did, so -- that references etc. will display in the expected places. Parameters that -- depend on another parameter are only processed if that parameter is present, -- to avoid phantom references appearing in article reference lists. local function parseDataParameters() preprocessSingleArg('autoheaders') preprocessSingleArg('child') preprocessSingleArg('bodyclass') preprocessSingleArg('subbox') preprocessSingleArg('bodystyle') preprocessSingleArg('title') preprocessSingleArg('titleclass') preprocessSingleArg('titlestyle') preprocessSingleArg('above') preprocessSingleArg('aboveclass') preprocessSingleArg('abovestyle') preprocessArgs({ {prefix = 'subheader', depend = {'subheaderstyle', 'subheaderrowclass'}} }, 10) preprocessSingleArg('subheaderstyle') preprocessSingleArg('subheaderclass') preprocessArgs({ {prefix = 'image', depend = {'caption', 'imagerowclass'}} }, 10) preprocessSingleArg('captionstyle') preprocessSingleArg('imagestyle') preprocessSingleArg('imageclass') preprocessArgs({ {prefix = 'header'}, {prefix = 'data', depend = {'label'}}, {prefix = 'rowclass'}, {prefix = 'rowstyle'}, {prefix = 'rowcellstyle'}, {prefix = 'class'} }, 50) preprocessSingleArg('headerclass') preprocessSingleArg('headerstyle') preprocessSingleArg('labelstyle') preprocessSingleArg('datastyle') preprocessSingleArg('below') preprocessSingleArg('belowclass') preprocessSingleArg('belowstyle') preprocessSingleArg('name') -- different behaviour for italics if blank or absent args['italic title'] = origArgs['italic title'] preprocessSingleArg('decat') preprocessSingleArg('templatestyles') preprocessSingleArg('child templatestyles') preprocessSingleArg('grandchild templatestyles') end -- If called via #invoke, use the args passed into the invoking template. -- Otherwise, for testing purposes, assume args are being passed directly in. function p.infobox(frame) if frame == mw.getCurrentFrame() then origArgs = frame:getParent().args else origArgs = frame end parseDataParameters() return _infobox() end -- For calling via #invoke within a template function p.infoboxTemplate(frame) origArgs = {} for k,v in pairs(frame.args) do origArgs[k] = mw.text.trim(v) end parseDataParameters() return _infobox() end return p
