Resistors - Repair Basics | |
Type | Component |
Device(s) | Resistors |
Difficulty | ◉◌◌◌ Easy |
What is a Resistor?
Voltage divider
Uses:
- And much more
Resistor sensors
Pull-up / Pull-down
Current measurement
Fixed value resistors
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors (LDRs)
Testing a Resistor
Replacement Considerations
