Transistors - Repair Basics | |
Type | Component |
Device(s) | Transistors |
Difficulty | ◉◉◌◌ Medium |
What is a Transistor?
Amplification
Switching
Voltage Regulation
Motor Control
BJTs come in two types:
NPN
PNP
N-Channel
P-Channel
Testing a Transistor
Make sure the transistor does not have any physical damage such as burn marks or corrosion first! That's the quickest way of identifying a faulty transistor.
Usually, transistors fail in a short circuit where all the pins are shorted together. In such instances, it becomes crucial to thoroughly inspect and measure the entire circuit, as this short circuit indicates an excessive current flow through the gate or base which could easily damage other components connected to the transistor.
BJTs
FETs
IGBTs
- Place the red probe on the emitter (E) and black probe on collector (C), you should measure a diode voltage drop (typically 0.6 - 0.7 V).
Replacement Considerations
BJTs
FETs
IGBT
