MacBook Pro A1502 2013-2014 No backlight repair
Revision as of 17:55, 8 November 2023 by ASRepairs (talk | contribs)
Device MacBook Pro A1502
Identifying and solving backlight issues on the A1592 MacBook. A MacBook Pro with no backlight on the display is experiencing an issue where the screen remains dark even though the computer is powered on and operational. This means that while the computer itself may be functioning, the display is not emitting any light, making it extremely difficult or impossible to see the content on the screen. Shining a strong light on the display at an angle might reveal that the content is indeed present, but the backlight is not illuminating it.
  • Short to ground on backlight output (if backlight fuse blown, check this).
  • Trace of backlight output interrupted (can be caused by corrosion, can be fixed with jumper wire)
Example video (Repaired all corrosion including: LED driver replaced, SMC reflow, Thunderbolt chip replaced, screen connector cleaned and connections resoldered, several corroded components in memory area and screen power area replaced, jumper wire for screen backlight output)
  • Bad screen/screen cable. If backlight voltage is 49–50 V, bad screen.
  • USING WRONG SCREEN! If you use a 2012 or a 2015 screen on a 2013–2014 A1502, IT WILL NOT WORK!
If the screen is shorting the backlight to ground, you can fix the screen if the capacitor/connector on the screen is bad, it just sucks to do. But it is the only option since this screen is no longer available.
You can fix the screen if the capacitor/connector on the screen is bad, it just sucks to do. But it is the only option since this screen is no longer available.
