Galaxy A33 5G No Display
Revision as of 01:05, 2 February 2026 by Ajimalg82 (talk | contribs)
Device Galaxy A33 5G
Affects part(s) Logic Board
Type Soldering, Teardown, BGA
Galaxy A33 screen does not respond at all. Displays no image, but there is a touch input on the entire panel. Replacing the screen does not fix the issue.
  • No display(graphics) on screen
  • Phone boots normally
  • Touchscreen works
  • Charges normally
The problem is due to a missing VDD_LCD_ELAVDD_7P6 signal.
Diode Value
  • Check GR on the connector (you will get a missing GR on a following pin)
    BURNED PIN
  • Check GR on the Capacitor where the area is burned, if GR is ok then proceed to do the jumper like in the following picture
    JUMPER
  • Test the display if it works
  • If everything seems fine cover the jumper with UV oil.
