How To Fix an iPhone 15 Pro That Randomly Restarts
Revision as of 00:34, 4 September 2024 by VCCBoardRepairs (talk | contribs) (added 0x600000 panic log)
Device iPhone 15 Pro, iPhone 15 Pro Max
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 15 Pro and iPhone 15 Pro Max to randomly restart every few minutes. For the iPhone 15 Pro series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
  • Back Glass/Wireless Charging Flex - This is the flex that wraps around the logic board & controls the power button.
    iPhone 15 Pro Max - Wireless flex diagram. If it's unplugged, it will restart giving panic log error 0x400000
  • Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
If you see:
  • 0x200000 - It's the Proximity Flex
    • Only affects the 15 Pro and not the 15 Pro Max
    • Diode mode the FPC connectors for any fault
  • 0x300000 - It's the Charging Port Flex
    iPhone 15 Pro Max Panic log example. It will restart if the charging port flex is unplugged, causing 0x300000 panic log error
    • iPhone 15 Pro Max will restart if the charging port flex is unplugged, causing 0x300000 panic log error
  • 0x400000 - It's the Wireless Charging Flex on the Back Glass
      Panic Log Example of 0x400000, which is due to the wireless charging flex being unplugged
  • 0x600000 - It's 2 problems, the Proximity Flex and Wireless Charging Flex
    • Make sure both flex cables are plugged in
  • 0x700000 - It's 2 problems: Charging Port Flex and Wireless Charging Flex
  • 0xa1 - It's a battery data issue.
    • Sometimes you'll see the battery percentage fluctuate or you'll randomly get a "non-genuine" message.
    • Check the battery connector pins. Sometimes they can bend out & battery won't make good contact.
    • Diode mode the battery connector pins & compare them to known good board
    • Test with a known good battery
    • Replace the battery connector
    • iPhone 15 Pro Max - Device will restart every 3 minutes if the battery is bad, giving error 0xa1
  • Bad or damaged flex
Please note: You MUST have the required flex cables, (Charging port flex, Wireless Charging Flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
