| Type | Component |
| Device(s) | Transistors |
| Difficulty | ◉◉◌◌ Medium |
What is a Transistor?
There are many types of transistors, with the main ones being: Bipolar Junction Transistors (BJTs), Field-Effect Transistors (FETs), and Isolated Gate Bipolar Transistors (IGBTs).
Transistors are typically identified by the symbols shown in Figure 1 and are usually denoted with the letter Q followed by an identifier number. (E.g., Q27). Discrete individual transistors come in plastic or metal packages with three or sometimes four terminals.
Amplification
Switching
Transistors can be used as electronic switches to control the flow of current in a circuit. They are used in digital logic circuits, microcontrollers, Power manager circuits, and more.
Voltage Regulation
A transistor may be used as a linear voltage regulator by dropping excess voltage from a source across itself, when controlled by a voltage reference, to produce a lower, stabilized voltage.
In switch mode power supplies, transistors are used for power conversion by rapidly switching on and off to either boost or step down the voltage depending on the circuit. By controlling the timing of their switching, voltage regulation can be achieved at the output.
Motor Control
BJTs come in two types:
NPN
PNP
A PNP transistor operates similarly to an NPN transistor, but the direction of current flow is reversed. Current flows from the emitter to the collector when a small current is pulled from the base. PNP transistors are also used for amplification and switching though they have become uncommon.
PNP transistors are particulrly common in older devices using Germanium transistors, made in the 1950's through the 1970's.
N-Channel
P-Channel
Internally, IGBTs are high power bipolar transistors driven by a built in MOSFET.
Testing a Transistor
Transistor testing methods depend greatly on the type of transistor and the failure modes trying to identify. A visual inspection should always be the first step. Some clear signs of likely deterioration or failure are listed as follows:
- Corrosion of the pins and metal shell (when applicable).
- Broken pins due to corrosion or mechanical fatigue from prolonged vibration.
- Discoloration of the transistor, the surrounding circuit or adjacent components, indicating overheating.
- Burn marks, holes and cracks on the transistor package.
Usually, transistors fail in a short circuit where some or all the pins are shorted together. In such instances, it may be necessary to inspect the rest of the circuit, both to find other components that may have been damaged by this short circuit, or failed components that may have caused the transistor to short in the first place.
Old metal package transistors may develop shorts as a result of the growth of tin whiskers inside the shell.
Transistors may also fail open on occasion, often caused by the breaking of internal bond wires due to overcurrent or fatigue. Degradation of the semiconductor due to age, or the intrusion of air or moisture can cause transistors to develop resistive leakages between its electrodes.
BJTs
The most basic test for a BJT is to check that the internal PN junctions are in good shape. Essentially, a BJT should test as two diodes with a common terminal like is shown on Figure 1. Failing this test is a good indication of transistor failure, but a transistor may still have other issues (such as emitter-collector leakage or short) even if the diode junctions test normally.
- If the pinout can't be found from documentation or inferred from the surrounding circuitry, it may be determined by probing different combinations of pins with the multimeter in diode mode, trying to find one of the two configurations shown on Figure 1. This can also clarify if the transistor is PNP or NPN. If the transistor has failed, it may not be entirely possible to find the pinout using this method.
- Transistors with metal shells often have a tab or a painted dot near the emitter, with the base being the closest pin to the emitter.
- It should be noted that some power BJTs have built in flyback diodes between the emitter and collector too.
- Test for shorts or leakage: Set the multimeter to the highest resistance scale (or autoscale).
- Measure the resistance between the collector (C) and the emitter (E). If you measure below 100 Ohms that means the BJT is shorted. You might find values in the tens of kilo ohms to mega ohms, which indicate a leaky transistor but don't necessarily imply the transistor is unusable (this depends on the circuit it's used in).
- Measuring this value with the probes reversed may point you towards the presence of an internal flyback diode if you find a low value in one direction and and a high value in the opposite direction.
- Test the internal junctions of the transistor: set your multimeter to diode mode.
- For an NPN transistor: Connect the red probe to the base (B) and probe the emitter and collector with the black probe. In both cases the multimeter should read a diode drop (typically 0.6 - 0.7 V or 0.2 - 0.5 V for old Germanium transistors).
- For a PNP transistor, repeat the same but reverse the meter probes (black on base), you should read the same diode values.
FETs
IGBTs
- Place the red probe on the emitter (E) and black probe on collector (C), you should measure a diode voltage drop (typically 0.4 - 0.7 V).
Replacement Considerations
BJTs
FETs
IGBT
