| Type | Component |
| Device(s) | Transistors |
| Difficulty | ◉◉◌◌ Medium |
What is a Transistor?
There are many types of transistors, with the main ones being: Bipolar Junction Transistors (BJTs), Field-Effect Transistors (FETs), and Isolated Gate Bipolar Transistors (IGBTs).
Transistors are typically identified by the symbols shown in Figure 1 and are usually denoted with the letter Q followed by an identifier number. (E.g., Q27). Discrete individual transistors come in plastic or metal packages with three or sometimes four terminals.
Amplification
Switching
Transistors can be used as electronic switches to control the flow of current in a circuit. They are used in digital logic circuits, microcontrollers, Power manager circuits, and more.
Voltage Regulation
A transistor may be used as a linear voltage regulator by dropping excess voltage from a source across itself, when controlled by a voltage reference, to produce a lower, stabilized voltage.
In switch mode power supplies, transistors are used for power conversion by rapidly switching on and off to either boost or step down the voltage depending on the circuit. By controlling the timing of their switching, voltage regulation can be achieved at the output.
Motor Control
BJTs come in two types:
NPN
PNP
A PNP transistor operates similarly to an NPN transistor, but the direction of current flow is reversed. Current flows from the emitter to the collector when a small current is pulled from the base. PNP transistors are also used for amplification and switching though they have become uncommon.
PNP transistors are particulrly common in older devices using Germanium transistors, made in the 1950's through the 1970's.
N-Channel
P-Channel
Internally, IGBTs are high power bipolar transistors driven by a built in MOSFET.
Testing a Transistor
Make sure the transistor does not have any physical damage such as burn marks or corrosion first! That's the quickest way of identifying a faulty transistor.
Usually, transistors fail in a short circuit where all the pins are shorted together. In such instances, it becomes crucial to thoroughly inspect and measure the entire circuit, as this short circuit indicates an excessive current flow through the gate or base which could easily damage other components connected to the transistor.
BJTs
FETs
IGBTs
- Place the red probe on the emitter (E) and black probe on collector (C), you should measure a diode voltage drop (typically 0.4 - 0.7 V).
Replacement Considerations
BJTs
FETs
IGBT
