Xerox WorkCentre 3655
This article is a stub. You can help Repair Wiki grow by expanding it. |
This page is a work in progress.
Problem | Solution |
Green Screen with the Energy Star Logo. |
Attempt a software "altboot" using a USB. Format the USB to FAT32. Obtain the software DML file from the download section of the Xerox website. Create a folder on your USB drive and name it "altboot". Place the DLM file in the folder and plug the USB drive into one of the USB ports on the back of the machine. Turn the machine on and wait. This procedure can take from 30 minutes to an hour to complete. Sometimes the machine will sit on a black or green screen for up to 15 minutes before going into the software mode. Failed HDD. This is a very common failure. You may replace the drive with another HDD of 120G or greater or with a SSD of 120G or greater. Once the disk drive is replaced, you will need to perform the altboot procedure to load software. ESS Sata damage Missing +5VDC from the HDD power cable. |
Green Screen without the Energy Star logo. |
