Xbox One S (1681)
This page applies to the Xbox One S, Xbox One S All Digital, and all of the associated special editions, because they all have the same motherboard. Note: Some ICs may vary.
All Xbox One S models have a built in power supply, unlike the Xbox One.
Because of the vent being on the top of the console, water damage is common.
WARNING: The disc drive is married to each console. For a proper disc drive change, change the PCB inside the new disc drive to the old one. Not doing so will render the console unusable.
Problem | Solution |
Shuts off after 10 seconds with fan spin |
Verify disc drive is connected properly, verify hard drive is healthy. Dead hard drive can cause this. |
No Power |
Check if you hear power supply chirping. Try inserting a disc. If chirping power supply and/or disc unsuccessful, you may have a shorted 12v rail/bad power supply.
if not the power supply check mosfets on board under heatsink they commonly fail on xbox one S |
Turns on but no output (black screen) |
Possible dead hard drive. Try going into safe mode. Possible HDMI circuit issues.
"Something went wrong" error on boot |
Possible corrupt (or too old) OS. Possible dead hard drive. Try reinstalling the Xbox operating system with a USB drive, following instructions on screen. If that fails, try a different pen drive, or you need to replace the HDD, or the recovery image is too old, and the device is trying to prevent a software downgrade. If you just downloaded the recovery image, wait for the next recovery image (usually takes 1-2 weeks), and try again |
Beeps but doesn't turn on or shuts down after 1-10 seconds |
Check for corrosion around TPS51916 RAM IC
A beep on and off error is the worst of the worst. It can be something very obvious, or a random blown resistor somewhere in a group of 100 components, and anything in between. |
Parts | Description | Source |
SN75DP159RSBT | HDMI Retimer IC U8B2 | Mouser |
TPN8R903NL,LQ | 4C50 Big Mosfet U9D2 See Fig. 1 | Mouser |
HDMI2C4-5F2 | HDMI ESD/Booster IC U8B1 See Fig. 2 | Mouser |
HDMI Filters/Chokes EG7B5 | ||
NCP5901BMNTBG | Mosfet Gate Driver Q9D2 See Fig. 3 | Mouser |
