Xbox 360 No Power
Jump to navigation
Jump to search
Xbox 360 No Power
No Power[edit | edit source]
Board is unresponsive to power button
Undo Bad Writes/Check For Faulty NAND
- The board cannot power on if it cannot load a valid SMC and config from the NAND flash
- Read NAND and check that the dump is valid
- If you cannot get valid flash config, continue to next step
- Replace NAND if flashing a valid image does not yield a valid read
- Some 4GB Coronas may have a faulty Phison (V2) or eMMC (V4/V6) chip, they must be replaced or downgraded to 16MB
- This is a common fault, where the controller wears out with extended use of the internal 4GB MU
- Usually the system will stop saving settings or updating before going completely dead due to controller degradation
- Can be diagnosed by attempting read/write
- If faulty, replace Phison/eMMC (U1E3) or convert the board to 16MB
- Ensure to program the correct image afterwards
- If the image could not be read/decrypted before replacing, boot XeLL to grab the CPU Key and LDVs and rebuild the image
Standby Power Rails
- Check for correct voltage and no short circuit in the following order:
Power Rail | Source | Location: Phat | Location: Trinity | Location: Corona |
V_5P0STBY | Standby 5V directly from PSU | FT8N1 | FT6M1 | FT6M1 |
V_5P0DUAL | 5V, switched between V_5P0STBY and V_5P0 | FT1R2 | FT1N9 | FT1N9 |
V_3P3STBY | 3.3V, created from V_5P0STBY | FT5N1 | FT5M1 | DB5A2 |
V_1P8STBY | 1.8V, created from V_5P0STBY | FT5N2 | FT5N2 | N/A |
V_1P2STBY | 1.2V, created from V_5P0STBY | N/A | N/A | DB3C2 |
Missing V_5P0STBY:
- This rail comes directly from the PSU. Check DC jack:
- Phat: J9A1 Pin 8
- Slim: J7A1 Pin 10
- Check for shorted filtering caps for V_5P0STBY:
- Phat: C5B7, C8B1, C9A4
- Slim: C6A1, C6A4, C6A5
Missing V_5P0DUAL:
- This rail comes from either V_5P0 or V_5P0STBY, depending on VREG_V5P0_SEL
- Check regulator pins 5-8 for 5 volts:
- Phat: U1R1
- Slim: U1B1
- Check front and rear USB port pins are not shorted or damaged
- Check VREG_V5P0_SEL is high (so that V_5P0DUAL will be created from V_5P0STBY)
- Phat: FT1R1
- Trinity: FT1P1
- Corona: FT2R1
- Check 4.75K Ohm resistor:
- Phat: R1D6
- Slim: R1P1
- If VREG_V5P0_SEL is still missing, replace Southbridge:
- If VREG_V5P0_SEL is still missing, proceed to the SMC Reset step
Missing V_3P3STBY:
- Phat:
- If U5B1 circuit is present:
- Check U5B1 regulator for shorts, NCP1117 or compatible
- Check C5B1, C5B2 for shorts
- If U9C1 circuit is present (Some Phat Jasper Kronos only)
- Some boards use this different circuit, manufacturer choice, U5B1 circuit will not be present
- Check U9C1 regulator for shorts
- Check R9C5: 0 Ohms
- Check C9C8, C9C10 for shorts
- Trinity:
- Check U5A1 regulator for shorts
- Check R5A11: 0 Ohms
- Check C5A1, C5A2, C5A3 for shorts
- Corona:
- Check R5A8, R5A12: 0 Ohms
Missing V_1P8STBY:
- Phat:
- If U5B2 circuit is present:
- Check U5B2 regulator for shorts, NCP1117 or compatible
- Check C5B4, C5B6 for shorts
- If U9D1 circuit is present (Some Phat Jasper Kronos only)
- Some boards use this different circuit, manufacturer choice, U5B2 circuit will not be present
- Check U9D1 regulator for shorts
- Check R9D4: 0 Ohms
- Check C9D5, C9D9, C9D10, C9D11 for shorts
- Trinity:
- Check R5B4: 0 Ohms
- Check C5B1, C5B2, C5B6, C5B7 for shorts
- Corona: See below, uses V_1P2STBY instead
Missing V_1P2STBY:
- This rail exists only on Corona and is a replacement of V_1P8STBY
- Check U5A2 regulator for shorts
- Check R5B4, R5A13: 0 Ohms
- Check C5A9, C5B1, C5B2, C5B3, C5B7 for shorts
SMC Reset
- SMC_RST_N must go high in order for the SMC to run
- It is controlled by ANA/HANA (integrated in Southbridge for Corona)
- Check that SMC_RST_N goes high (3.3V):
- Phat: J2B1 Pin 5
- Slim: J2C3 Pin 5
- Corona: If R2C10 is missing, check R2C10 S Pad instead, resistor is not needed
- If missing signal:
- Phat:
- Check R2P18: 100 Ohms
- Check R2P1: 10K Ohms
- Check R2P3: 1K Ohms
- Check C3P9 for shorts
- Trinity:
- Check R3R13: 100 Ohms
- Check R3R15: 10K Ohms
- Check R3R16: 1K Ohms
- Check C3R2 for shorts
- Corona:
- Check R2C10: 100 Ohms
- Check R3P15: 10K Ohms
- Check R3P16: 1K Ohms
- Check C2P51 for shorts
- Phat:
- If still missing signal:
- Xenon: Replace ANA U4C2
- Zephyr, Falcon, Jasper: Replace HANA U4C2
- Trinity: Replace HANA U3B1
- Corona: Replace Southbridge U3D1
Standby Clock
- STBY_CLK is created by the ANA/HANA and is used to run the System Management Controller (8051 core) in the Southbridge
- Phat/Trinity:
- Check STBY_CLK for 48 MHz single-ended clock:
- Phat: FT2R2
- Trinity: FT3N2
- If bad/missing signal:
- Check master crystal Y3B1 for 27 MHz single-ended clock
- Check STBY_CLK resistor for 33 Ohms:
- Xenon: R3B7
- Zephyr, Falcon, Jasper: R4B24
- Trinity: R3B15
- Replace clockgen chip:
- Xenon: Cypress CY28517 U3B4
- Zephyr, Falcon, Jasper: HANA U4C2
- Trinity: HANA U3B1
- Corona:
- These boards do not have a STBY_CLK signal as the clockgen was integrated with the Southbridge (KSB), it is generated internally
- Check master crystal Y3D1 for 25 MHz single-ended clock
- This is as far as we can check STBY_CLK circuit on these boards
Southbridge
- If all else fails, Southbridge is bad and must be replaced:
- Phat: U2C1
- Slim: U3D1
Credit[edit source]
Original article credit: Octal450
