Wii Remote
Jump to navigation
Jump to search
Problem | Solution |
Wii remote not turning on |
Check Battery Contacts. If device is not taking power:
If it is unreliable, or if there is battery acid on the plate, remove the spring from the plate, and put it in a small container of white vinegar. If there is a large amount of acid on the plate, it might be best to remove the plate and put it in white vinegar. Resolder the plate back onto the logic board. Test. |
