Sennheiser HDR 180
This article is a stub. You can help Repair Wiki grow by expanding it. |
Sennheiser HDR 180 are headphones that go with the Sennheiser TR 180 transmitter, Combined together make the RS 180 series.
Common Issues[edit | edit source]
Problem | Solution |
LED Flashes for 5 seconds then off for 5 seconds. |
The headphones may be interrupted by a Wi-Fi signal from a computer, or router that prevents it from connecting to transmitter. Try moving transmitter away from any Wi-fi emitting sources. This also includes microwaves which can also block signals from the transmitter to the headphones and vice versa. |
Headphones not charging |
Clean the gold charging connectors on headphones and the transmitter with a cloth, or q-tip. The gold connectors can sometimes build up with oils from hair which disrupt charging ability. |
Worn ear pads |
Hold the outside of ear pads and turn anti-clock wise. New ear pads are available on the Sennheiser website, or available through third party. |
- ↑ Sennheiser RS 180 Instruction manual | https://assets.sennheiser.com/global-downloads/file/959/RS180_US_INT.pdf
- ↑ Sennheiser RS 180 specifications sheet | https://assets.sennheiser.com/global-downloads/file/2588/RS180_spec_engl.pdf
