Samsung Galaxy Tab A
Jump to navigation
Jump to search
This page covers the 2016 model of the Samsung Galaxy Tab A T560
Problem: | Possible issues: | Solution: |
Tablet doesn't seem to turn on, hard reset won't work | The tablet is frozen | Remove the backplate. To confirm, check battery voltage. 3.5-4 V should be fine. Unplug the battery wait a few seconds and plug back in. |
Charging or screen cable came loose | Remove the backplate, check and fix loose connections. | |
Battery tab broken, battery is dead | Remove the backplate. To confirm: check battery voltage. Below 3V is probably a battery or charging issue. Change the battery. | |
Lcd Connector Clip broken | Physical Damage | Put a piece of tape under the lcd cable, and then insert in the lcd connector . It ll push the cable to make contact and then put a piece of tape on top of the cable so it does not move . |
Screen Shuts Off after replacement or Turning Black | The tablet believes it has a smart cover on it | Easiest Solution is to Remove all the magnets found inside the tablet that attach to the smart cover . Downside is that the smart cover wont attach magnetically . |
