Samsung Galaxy S series
This is a page for Samsung's Galaxy S series of phones. Not to be confused with their Samsung Galaxy Tab S series of tablets
Samsung Galaxy S[edit | edit source]
Samsung Galaxy S2[edit | edit source]
Samsung Galaxy S3[edit | edit source]
Samsung Galaxy S4[edit | edit source]
Samsung Galaxy S5[edit | edit source]
Samsung Galaxy S6[edit | edit source]
Samsung Galaxy S7[edit | edit source]
Samsung Galaxy S8[edit | edit source]
Samsung Galaxy S9[edit | edit source]
Samsung Galaxy S9:[edit | edit source]
models (Three variants for Samsung International, Korea Versions (Not popular in most regions) and USA/CANADA versions[edit | edit source]
G960U/U1/W - QCOM[edit | edit source]
G960F - Exynos[edit | edit source]
G960N - Exynos[edit | edit source]
Problem Solution
No Power, No draw on DC power Supply, and When you prompt to boot no reaction on DC Power Supply.
Knowing device history: do a quick history on what meant have caused the issue at hand, from their do a quick visual inspection of device. Now if everything checks out lets proceed to checking important rails needed for device to power on. Receiving such a case is something which is not common but over the years of repairs i have seen most of such cases. normally caused by AP PMIC
let's go to steps to follow if no power
  • Check the signal on AP_PS_Hold=1.8V, Note: if this rail is present and voltage matches or within a margin of - or + 10% margin,
Also: check if the battery has sufficient voltage level = 3.5V, anything below 3V, means try another battery or charge is externally and test again. If using dc power supply confirm the FPC has good contact with probes (connector from DC Power supply).
TP_PS_HOLD
  • Power Key: Yes the most innocent victim, This is supposed to have 1.2V before prompt to boot, so while dc power supply or battery is connected this rail will have that voltage with margin error of reading between - or + 10%. When you press power key it shorts to ground and registers low voltage, always diagnose this on such a case. If rail is missing check component next in line on the SW_ON rail.
  • Voltage Rail Missing on Power Key: If this is the case then check out rails from main AP PMIC, will create a dedicated topic on this below (Those in a hurry; check out rails from Main PMIC - Make sure you also check PMIC_PON_RST_N Rail and PON_1
TP: Close image picture
Samsung Galaxy s9+:[edit | edit source]
Samsung Galaxy S10[edit | edit source]
Samsung Galaxy S10e:[edit | edit source]
Samsung Galaxy S10:[edit | edit source]
Samsung Galaxy S10+:[edit | edit source]
Samsung Galaxy S10 5G:[edit | edit source]
Samsung Galaxy S10 Lite:[edit | edit source]
Samsung Galaxy S20[edit | edit source]
Samsung Galaxy S20:[edit | edit source]
Samsung Galaxy S20 Plus:[edit | edit source]
Samsung Galaxy S20 Ultra:[edit | edit source]
Samsung Galaxy S20 Fan Edition:[edit | edit source]
Samsung Galaxy S21[edit | edit source]
Samsung Galaxy S21:[edit | edit source]
Samsung Galaxy S21 Plus:[edit | edit source]
Samsung Galaxy S21 Ultra:[edit | edit source]
