Samsung Galaxy Note series
Problem Solution
Unresponsive boot into the phone even when replacing the battery and plugging up phone note 4/5 and older particularly the 4/5 series suffer from nand solder balls popping and applying and keeping pressure over the nand will normally allow the phone to boot to retrieve data
Galaxy Note 10 & Note 10 Plus
Problem Solution
Doesn't charge.
Shows Temperature Warning
In most cases, this is caused from the NFC/Wireless Coil connector on the board.
Usually it happens after the back glass breaks, which ends up pushing & breaking the NFC connector which is weak, for some reason.
So it requires you to replace the NFC to repair it.
Here's a full video tutorial on the repair: https://youtu.be/jpwMbt2L2-I
Galaxy Note 8[edit | edit source]
Problem Solution
Doesn't charge.
Phone says it is charging, but pulls 0 amps, and does not go up any percentage
Replace PMIC SM5720
