We will be continuing maintenance on the wiki starting this Saturday at 9 am (UTC) to Sunday at 7PM (UTC).
There is a possibility of long maintenance-breaks and downtime during this time.
For more information contact us in the wiki Discord or by email at: unto@fighttorepair.org
Powerbook 145B
The Macintosh PowerBook 145B was one of Apple's early laptops in the Powerbook 1xx line. It was introduced on June 7th, 1993 and discontinued on July 18th, 1994.
System Specifications[edit | edit source]
Notes | ||
CPU | Motorola 68030 @ 25 MHz | Soldered to CPU Card |
FPU | None | |
RAM | 4 MB 100ns PSRAM | Soldered to CPU Card. Upgradeable to 6 or 8 MB using a single 2 or 4 MB 70 pin proprietary memory card plugged into CPU card. |
HDD | Internal 40 or 80 MB SCSI | Internal drive type is 2.5" 40 pin SCSI, which was not a commonly used standard. |
FDD | 1.44 MB 3.5" | |
Display | 9.8" 640x400 Monochrome Passive Matrix STN LCD Display | |
Expansion Slot | Optional 2400 Baud Modem | Internal module plugged into main logic board. |
Expansion Bay | N/A | |
Keyboard | Integrated 63 key | No numeric pad. |
Mouse | Integrated trackball with two buttons | |
Ports | Serial, Printer, Speaker Out, Microphone In, ADB, HDI-30 SCSI, RJ-11 Modem (Optional) |
Battery | 1 x 2800 mAh Nickel Cadmium Battery | These batteries are prone to leaking and should be stored outside of the unit when not in use. Original battery packs are going to have long since expired and should be serviced/rebuilt before use. |
PRAM Battery | 1 x 3.0 Volt VL-3220 | Soldered to 820-0411-02 board inside the laptop screwed to the back of the upper case half. This is a rechargeable battery, DO NOT substitute with a normal CR type non-rechargeable battery. |
Power | 7.5 Volts @ 2.0 Amps | Barrel connector is center positive. The OEM charger is known to suffer from capacitor failure, check its output before using it. |
Known Issues[edit | edit source]
Like with anything, vintage computers have issues associated with them, the PowerBook 145B being no exception. Many of these are age related, but some are original manufacturing defects, and others can be caused by neglect. The PowerBook 145B was one of Apple's better laptops, but the machine can have serious issues if preventative maintenance and care in storing the machine are lacking.
The most common types of damage typical with older Apple Macintosh computers are leaking capacitors, leaking PRAM batteries and with PowerBooks, leaking main batteries. This damage is often caught far too late due to such machines being stored in attics, basements, sheds, etc. and long forgotten about by the original owner. Eventually such machines will be rediscovered during events such as moving, cleaning or estate sales, but the damage done by leaking capacitors and especially batteries has long since happened. You just have to hope that the machine was stored in such a way to minimize the effects of damage done so the device can be repaired.
The most destructive types of damage that can occur in older Macintosh machines are colloquially known in the vintage Macintosh community as "battery bombs", where the Parameter RAM (PRAM) battery casing fails and leaks its corrosive electrolyte all over the board and causes damage to whatever it touches. In PowerBooks, the Nickel Cadmium main battery can cause much more damage due to more batteries being present in the pack. And while the PowerBook 145B doesn't have the same type of PRAM battery used in desktop Macintosh models, it does have a rechargeable button cell battery that can leak and should be replaced as part of preventative maintenance.
Troubleshooting[edit | edit source]
Below is a table of some known issues with the machine and some potential fixes.
Problem | Solution |
Won't power on |
Powers on and bongs, but no display |
Powers on and bongs, but garbled display or |
Powers on and plays "chimes of death" with sad mac and hex error codes |
Keyboard doesn't work and/or stuck keys |
Trackball doesn't work or erratic movement |
Powers on, but displays disk with question mark |
Powers on, but displays disk with an X inside it |
