We will be continuing maintenance on the wiki starting this Saturday at 9 am (UTC) to Sunday at 7PM (UTC).
There is a possibility of long maintenance-breaks and downtime during this time.
For more information contact us in the wiki Discord or by email at: unto@fighttorepair.org
Percussive solder removal
This article is a stub. You can help Repair Wiki grow by expanding it.
Percussive solder removal is a method of desoldering that does not involve wick or solder suckers, but beating the board against a hard or semi-hard surface to fling the solder away. While potentially more dangerous than either of the other methods, in a pinch, or for really tough through-hole jobs, it can be effective.
  Step 1. Heat the solder on the location you wish to remove it.
  Step 2. Beat the board against a hard or semi-hard surface, aiming the molten solder away from any exposed body parts.
  Step 3. Clean up solder. In many cases, this can be done with a broom and dustpan, and the solder tends to solidify on the way to whatever surface it lands on.
