Nvidia Pascal GPU Diagnosing Guide (1060-1080ti)
This guide is applicable for most pascal cards from 1060 to the 1080ti, some vendors may create different PCBs or use different components but the general working principles for all of them should be the same unless specified. This guide uses a reference GTX 1080 as an example.
The Card.[edit | edit source]
GTX 1080 Reference board (Figure 1)
*PCB Image courtesy of TechPowerUp*
Before doing anything, it's a good idea to inspect the card for physical damage. Especially cards that have no backplate. They can easily lose some components on the back due to poor handling.
After making sure there is no physical damage to the card itself you can now move on with a multimeter to check the resistances of the voltage rails.
Step 1: Base Voltage Rails (12V, 3.3V)[edit | edit source]
The base voltages are the ones that get supplied to the card through the motherboard and the external 8pin power connector(s). What are the Base Voltage rails for GPUs?
12V rails[edit | edit source]
The card gets supplied 12v through the PCIe slot and additional 6-8 pin connector(s)
Start by measuring the resistances of the 12V rail coming from the PCIe slot (first 3 pins, see figure 1).
After that, measure each inductor for external power connectors (some cards have multiple external power connector and each of them have their own inductor you have to measure each of them individually).
The resistance varies from card to card and the value itself doesn't matter but it should be in the thousands+ Ω range.
3.3V rail[edit | edit source]
The card gets 3.3V from the PCIe slot only, from the 4th pin going left from the PCIe key notch in the front, and 2nd and 3rd pins on the back going from the notch again.
If you get less than 50Ω on one or multiple base rails then you have a card with a short. The computer might not turn on in such a case because the power supply is protecting itself using OCP (over current protection). Solution: Check out this page dedicated to Base Voltage Rail Short on Pascal GPUs.
Otherwise, if you have no short then you can continue troubleshooting.
Step 2: Minor Voltage rails. (5V, 1.8V, VCore, VMem, and PEX)[edit | edit source]
Minor voltage rails are the ones created by the card itself using the base rails through either Linear Voltage Regulators or Step Down Buck Converter
Check the resistance of the output of those rails and compare them with Figure 1. VCore has such a low resistance on 1000+ series cards that you won't find it useful to measure its resistance. A more helpful way is to measure its resistance against the 12v rails not GND.
If you get lower resistance on one or more of those rails, head to their pages linked below.
Otherwise, continue with the guide.
Step 3: Powering on the card.[edit | edit source]
Assuming you have no shorts anywhere you can go ahead and plug the card into the motherboard and start testing (Alternatively, you can use a Lab Bench Power Supply and a riser to test the card with. Safer for the motherboard and gives you more freedom to move the card around and you get to know the current draw of the card if there is a short).
Switch your multimeter to DC Voltage mode and start by measuring the base rails first, if they are present continue to the minor rails.
Minor rails turn on in series, if one doesn't start, the next ones in series will not turn on.
Power sequence[edit | edit source]
The order in which they turn on in most pascal GPUs is as follows: 5V→ 1.8V→ VCore→ VMem/PEX.
For example, if 5v does not turn on, everything else in the chain won't turn on either. Hence no fan spin if you have a problem with 5V or 1.8V.
If you're missing one of them, check their respective page:
Step 4: No Video Out.[edit | edit source]
Everything is present but still no video out? You either have faulty Memory, Bios, GPU chip itself, or in some cases a problem with straps.
Memory problems[edit | edit source]
If you've reached this point, the most likely culprit is the Memory. You can confirm this by powering on the card on the motherboard and plugging it in to the monitor, after a minute or so the monitor's backlight should turn on but without an image.
That behavior means the card initialized but detected a memory failure. Here: Nvidia Memory Testing Guide. is how to detect the faulty memory chips.
BIOS problems[edit | edit source]
If the memory is okay or the card is not even being detected in MATS then the problem is highly likely to be the bios. Check: BIOS Problems on Pascal GPUs.
Straps[edit | edit source]
Assuming there is no physical damage to the resistors, check their values out side the circuit. Sometimes *rarely* they change in value. Below is their location (figure 2) and their schematic (figure 3).
GTX 1080 Straps location on the board. (Figure 2)
Schematic view of 1080 straps (Figure 3)
