| Nintendo Wii The Picture is Noisy, Bad, Glitching, or Missing | |
| Device | Nintendo Wii |
| Needs equipment | |
| Type | |
- The Picture is Noisy
- The Picture is Bad
- The Picture is Glitching
- The Picture is Missing
- Check to make sure the power brick is outputting 12 volts DC.
- If it is, open the Wii and check the SMD Electrolytic capacitors on the board. The easiest way to check if the video filter SMD capacitor is faulty is to use a composite cable and check the video signal before and after going into the capacitor. Video source: https://youtu.be/sdWmm33VzBM?t=416.
- Other causes include use of poor quality or malfunctioning wii2hdmi or other component to hdmi converter devices.
