NAD Monitor Series 3400
The NAD 3400 was their top of the range integrated amplifier built between 1985 and 1989.
Problem | Solution |
Device stuck in stand by |
Replace all electrolytic capacitors on the digital control board 72-2284-0-0. The 5.5 V cap is a 47,000 μF (47 mF) supercapacitor. |
Speaker relays not working or working intermittently |
Resolder and clean switches "Speaker A" and "Speaker B" at front panel, reflow solder joints on speaker relays. |
Broken bass/treble potentiometers |
These are dual gang 4-pin potentiometers. The 4th pin is a center tap used for better precision. A dual gang center tapped logarithmic potentiometer of the correct value, that fits physically is not easy to find. I managed to find a replacement on Aliexpress. |
bass/treble controls not working as intended |
clean both frequency selection switches with a lubricating electronics cleaner (I use Tuner 600). |
Credit[edit source]
Original article credit: AMelbye
