Miniware DSO213
DSO213/DS213 is a "quad channel" pocket oscilloscope from Miniware. It is a great starting oscilloscope and as it is battery powered, it is floating compared to mains earth, so it is in some cases usable as a differential probe.
Doesn't power on[edit | edit source]
Problem Solution
Doesn't power on via battery, only from USB. Draws 50mA from the battery even when powered off
  • Replace the battery charging chip, CE3150AM, marked as U16
  • The device is fully functional when powered from USB regardless of this chip
