Matsuura 1998 MC 510-VG
This article is a stub. You can help Repair Wiki grow by expanding it. |
This is an old CNC vertical milling machine. There is poor support from the company as the knowledge seemed to have left with retired employees and most efforts are placed towards their newer models. These machines are built well and can be bought and rebuilt for well under the cost of a hobby grade CNC machine with all the benefits of strong cast iron foundation and the rigidity and using larger BT40 style tool holding.
CNC Machines:Brand_Matsuura Type.
MATSUURA MC-510 VG[edit | edit source]
Problem | Solution |
WAY OIL NOT DISTRIBUTING WITH PUMP TURNING ON |
REPLACE METERING VALVES WHICH MIGHT BE CLOGGED. |
WAY OIL NOT DISTRIBUTING OIL AND LUB PUMP NOT TURNING ON |
LUBRICATION PUMP MOTOR MIGHT HAVE FAILED, SHOULD REPLACE MOTOR. |
3481 YE-NET I/O ERROR NO.O1 |
<WAY OIL SYSTEM>[[Category:CNC MACHINE]</WAY OIL SYSTEM>
Way Oil Distribution
CNC MOTHERBOARD JANCD - JMM01
