MXL7704 (Raspberry Pi)
This article is a stub. You can help Repair Wiki grow by expanding it.
The MXL7704[1] is a programmable quadruple step-down DC/DC converter that is used in the following Raspberry Pi models:
  • Raspberry Pi 3 (A+ and B+) (MXL7704-R3 version)
  • Raspberry Pi 4 (all) (MXL7704-P4 version)
The MxL7704-AQB, MxL7704-XQB, MxL7704-R3 and MxL7704-P4 might be replacable[2] by the one time programmable (OTP) successor MxL7704-BQB[3]
The new model may be (one time) programmable to match the specific raspberry pi model default values.
Common cause of failure[edit | edit source]
If the Pi's 5V pin is shorted to the neighboring 3.3V pin, the MXL7704 will try to clamp the voltage on the 3.3V line. This destroys the MXL7704 chip, leaving the 3.3V line permanently shorted to GND.
Configuring[edit | edit source]
The MXL7704 chip can be configured via an I2C interface. The I2C address depends on the version of the chip:
Version Address
AQB and XQB versions
0x2D
R3 version (Raspberry Pi 3)
0x1D
P4 version (Raspberry Pi 4)
0x1B
Despite having a different I2C address, the R3 version of the chip will be correctly recognized by the OS if it's installed in a Raspberry Pi 4.
Note that any changes made to the configuration are not permanently stored. Every time the chip is powered off, its default configuration is restored. Different versions of the chip have different default configurations:
Model Default configuration
pi@raspberrypi:~ $ i2cdump -y 1 0x1d
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: a0 01 e4 27 43 57 27 00 00 00 02 00 XX XX XX XX    ???'CW'...?.XXXX
10: a5 a5 5a c0 c0 e4 1f 48 10 a9 7f 67 00 00 XX XX    ??Z????H???g..XX
Raspberry Pi 4
pi@raspberrypi:~ $ i2cdump -y 1 0x1b
10: a5 a5 5a b0 a5 e4 de 48 10 e9 5e 66 00 27 XX XX    ??Z????H??^f.'XX
Here's the meaning of the two default configurations (for more info, see the datasheet linked at the bottom of the page):
Address Setting Raspberry Pi 3A+ / 3B+ Raspberry Pi 4
Value
Meaning
Value
Meaning
0x02
Phase interleaving
0xe4
1 → 2 → 3 → 4
0xe4
1 → 2 → 3 → 4
0x10
V_out LDO
0xa5
3.3V
0xa5
3.3V
0x11
V_out buck 1
0xa5
3.3V
0xa5
3.3V
0x12
V_out buck 2
0x5a
1.8V
0x5a
1.8V
0x13
V_out buck 3
0xc0
1.2V
0xb0
1.1V
0x14
V_out buck 4
0xc0
1.2V
0xa5
1.03V
0x15
Buck Sequence Group Assignment
0xe4
  • 1: group 0
  • 2: group 1
  • 3: group 2
  • 4: group 3
0xe4
  • 1: group 0
  • 2: group 1
  • 3: group 2
  • 4: group 3
0x16
  • LDO Sequence Group Assignment
  • Channel Enables
0x1f
  • group 0
  • all enabled
0xde
  • group 3
  • bucks enabled, LDO disabled
0x17
  • SEQ EN Assign
  • PG1 Routing
0x48
  • SEQ EN: group 1
  • PG1 Routing: buck 4
0x48
  • SEQ EN: group 1
0x18
PG2 Routing
0x10
buck 4
0x10
buck 4
0x19
  • Fault Actions
  • Down Sequencing
  • Frequency
0xa9
  • Reset whole chip if any channel faults
  • Soft power off disabled
  • 78 Ω discharge enabled
  • 1.81 MHz
0xe9
  • Soft power off enabled
  • 1.81 MHz
The following pads can be used to acces the I2C interface:
Model SDA SCL
PP60
PP59
Raspberry Pi 4
The relevant traces
Compute Module 4 (CM4)[edit | edit source]
Since the LDO VIN is shorted to ground by CM4's layout design, the MxL7704-P4 (where the LDO is disabled by default programming) has to be used.
When using the MxL7704-R3 variant (which is the one available in aliexpress), the CM4 will not start since the LDO is assigned to group0 and can not start - so group0 can not start. With it all the buck converters stay disabled.
An tested alternative for using MxL7704-R3 for repairing CM4 is to disconnect Pin8 (LDO) and Pin7 (VIN) from the board and connect it (Pin7) permanently with +5V instead.
References[edit | edit source]
  1. MXL7704 datasheet, MaxLinear, Inc., 2018
  2. MXL7704 Product Discontinuation Notice, MaxLinear, Inc., 2021
  3. MXL7704-BQB datasheet, MaxLinear, Inc., 2022
