The 2020 iPhone SE was officially marketed as iPhone SE (2nd generation).
Models |
Region
A2275 |
United States, Canada
A2296 |
Global
A2298 |
China
Problem
3 Minute Restarting
Random Restarting
iPhone SE 2020 models require certain sensors to be detected by the operating system, otherwise it will reboot every 3 minutes & record this error in the panic log.
There are 3 sensors that must be detected.
On the Charging Port, there is:
On the Power Button Flex, there is:
To find the panic log on the device, go to Settings-> Privacy-> Analytics & Improvements-> Analytics Data-> Scroll down to the files starting with "panic-full..." & click on the most top one.
If you find the above errors, replace the appropriate flex with an OEM or Premium flex.
- Bad or damaged flex
Please note: You MUST have the required flex cables, Power Button & Charging Port, plugged in. Otherwise it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
See this video for a full tutorial on reading the panic logs & how to use the iDevice Panic Log Analyzer tool: https://www.youtube.com/watch?v=QaJLYbtuCGA
A list of other panic log errors that may encounter: https://vccboardrepairs.com/panic-log-list/
