iPhone 4
Jump to navigation
Jump to search
The iPhone 4 was the first iPhone with squared edge and all glass and metal construction.
Common issues[edit | edit source]
- Loss of cellular signal when holding the phone "wrong" by using the left hand causing the skin of the hand to make contact with the antenna and bridging the two metal pieces on the lower left of the phone. A potential solution is using a non conductive case.
- The home button will stop working after common wear and tear. Unfortunately unlike the iPhone 5, the replacement of the home button is not easy and a common fix is to use Assistive Touch, an accessibility feature of Apple iOS.
Back glass replacement[edit | edit source]
The back glass is easily replaceable by unscrewing the two screw on the bottom of the phone (on both side of the 32 pin connector) and pushing up to free it from the body. No cables are attached to the back glass so you can freely pull it off.
Models |
A1332 |
A1349 |
