| How To Fix iPad Pro 12.9 1st gen Bootlooping Every 10 to 15 Seconds | |
| Device | IPad Pro 12.9 1st Gen |
| Affects part(s) | Software |
| Needs equipment | PC, Internet Connection, IPSW File |
| Type | Software Flashing"Software Flashing" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property. |
Apple iPad Pro 12.9-inch (A1584) intermittently reboots every 10–15 seconds. When connected to diagnostics tools, the panic log reports consistent watchdog resets caused by SpringBoard failing to check in.
- iPad restarts in a loop every 10–15 seconds.
- Unable to reach the Home Screen long enough to interact.
- Panic log contains repeated lines such as:
- “userspace watchdog timeout: no successful checkins from SpringBoard”
- “SpringBoard last successful checkin: 0 seconds ago”
- System may show additional services not checking in (backboardd, mediaserverd, wifid), which is normal when SpringBoard fails first.
- Unplugging all flexes also doesn't fix the issue.
1. Read Panic Log
Open the panic log from the iPad or using 3UTools:
Look for:
- userspace watchdog timeout
- no successful checkins from SpringBoard
- last successful checkin: 0 seconds
Interpretation:
This is almost always a software-layer failure, not a hardware issue. SpringBoard isn’t responding, so watchdog forces a reboot.
2. Rule Out Hardware
Check:
- No signs of liquid or board short
- Battery level stable
- Device boots and displays Apple logo normally before reboot
- Unplug all flexes which may cause reboots.
If these conditions are normal, hardware is not the cause.
3. Perform Clean Flash
Use:
- Apple Configurator / Finder
- 3uTools, etc.
Select Clean Flash in 3UTools and Restore in Finder so system partitions fully rewrite.
- Put iPad into DFU Mode
- Connect to Mac/PC
- Hold Home + Power
- Release Power after 10 sec while holding Home
- DOWNLOAD Load IPSW Firmware
- Choose latest signed IPSW for A1584 FROM IPSW.ME
- Select Restore on Finder (not Update) & Clean flash on 3UTools
- Erase & Flash
- Allow full system erase
- Allow Full Boot
- After restore, device should remain stable without rebooting
- Verify Functionality
- Let it idle for 5–10 minutes to confirm loop is resolved
