How To Fix Poco X3 Pro Dead or Camera Not Working or No Audio Issue
Device Poco X3 NFC, Poco X3 Pro
Needs equipment Hot Air Station, Soldering Iron, Tweezers, Low Melt Solder, Board Holder, CPU Stencils
Difficulty ◉◉◉◉ Specialist
Poco X3 and X3 Pro presents with severe system failures such as no power, non-functional cameras, and no audio output. In many cases, the device appears completely dead or fails to boot properly.
When powered via a DC power supply, the phone draws ~0.150 A after a boot prompt and then stalls, indicating that the CPU is attempting to initialize but fails shortly after.
This is a well-known defect on the Poco X3 Pro and is caused by CPU solder joint failure due to thermal stress and board flex.
Poco X3 (Figure 1) -- Camera not working even after replacing with known good parts
  • No audio (speaker, earpiece, microphone all dead)
  • Rear and front cameras not detected / not working
  • Device does not power on
  • Black screen, no vibration
  • Stuck at ~0.150 A on DCPS after pressing power
  • No further current ramp (no boot)
  • Issue persists after:
    • Replacing battery
    • Replacing screen
    • Replacing cameras or audio components
Poco X3 Pro (Figure 2) -- CPU location
Poco X3 Pro CPU (Figure 3) -- CPU reballed
  1. Connect device to DCPS
  2. Press power button
  3. Observe current behavior:
    • ~0.150 A stall confirms CPU fault
  4. Confirm no shorts on main power rails
  5. Rule out:
    • PMIC failure
    • Battery fault
    • Display fault
Once these are ruled out, proceed with CPU repair.
  1. Remove logic board from device
  2. Shield surrounding components
  3. Preheat board evenly to avoid warping
  4. Remove CPU using controlled hot air
  5. Clean CPU pads and board pads thoroughly
  6. Reball CPU with correct solder size
  7. Inspect balls under microscope
  8. Reinstall CPU carefully aligned
  9. Reflow evenly and allow to cool naturally
  10. Clean flux residue
