Google Pixel 6 Pro
The Google Pixel 6 Pro is the successor to Google's "XL" lineup of phones, the "Pro" model of the standard Google Pixel 6. Running Google's "Tensor" chip, Google's first in-house designed SoC manufactured by Samsung, with the following specifications:
  • Chipset:[1]
    • CPU:
      • 2× Cortex-X1 @ 2.8 GHz
      • 2× Cortex-A76 @ 2.25 GHz
      • 4× Cortex-A55 @ 1.8 GHz
    • Lithography: Samsung 5 nm
    • GPU:
      • 20× Mali G78 MP20
      • 848 MHz shaders
      • 996 MHz tiler/L2
    • NPU: Google EdgeTPU @ 1066 MHz
    • ISP: Hybrid Exynos + Google
    • Memory Controller: 4× 16 bit @ 3200 MHz LPDDR5 w/ 8 MiB cache
    • Modem:[2]
      • Exynos 5123
        • 2G
          • 850, 900, 1800, 1900 MHz
        • 3G
          • 1,2,4,5,6,8,19
        • LTE Cat 24/18
          • B1/2/3/4/5/7/8/12/13/14/17/18/19/20/25/26/28/29/30/32/38/39/40/41/42/46/48/66/71
        • 5G NR Sub-6
          • n1/2/3/5/7/8/12/14/20/25/28/30/38/40/41/48/66/71/77/78
        • 5G NR mmWave (Locale dependent)
          • n257/n258/n260/n261
  • Display: OLED 6.71" 1440 × 3120 (512 px/in) at 120 Hz variable refresh rate and HDR10+
  • RAM: 12 GiB
  • Storage: UFS 3.1
    • 128 GB (all colors)
    • 256 GB (white and black only)
    • 512 GB (black only)
  • Battery: 5000 mAh non-removable
  • Rear cameras:
    • 50 Mpx ƒ/1.9 wide OIS
    • 48 Mpx ƒ/3.5 telephoto/periscope OIS 4× optical zoom
    • 12 Mpx ƒ/2.2 ultrawide
  • Rear video capture:
    • 4K 30/60 fps
    • 1080p 30/60/120/240 fps
  • Front camera:
    • 11.1 Mpx ƒ/2.2 ultrawide with 4K 30 fps or 1080p 30/60 fps video capture
Official Pixel 6 Pro Repair Manual by Google: External MEGA Link External Catbox Link
Problem(s) Solution(s) Citation
Rear camera is poor quality after camera module and/or logic board replacement
  • According to the official service manual, if the camera or logic board needs to be replaced, you need to use a "GEO" camera module provided to Authorized Service Providers; this module is different from the production camera module that is somehow paired to the original logic board. In actual tests on production units, swapping the main board or cameras between two production devices does not break the camera, but comprehensive quality tests have not yet been performed to determine if the mismatched calibration data makes any perceptible difference in camera quality.
Display touch screen inaccurate after installing new display assembly
  • According to the official service manual, after replacing the display assembly do not power on the device until these conditions are met: Nothing touching the display including dirt, debris, screen protectors, shipping protection, etc. Lay device on a flat surface, preferably in a jig that accounts for the camera bump
  • Power on the device without touching the screen until the OS has fully booted and shows a lock screen
Fingerprint sensor not functioning after replacement
  • The Pixel 6 Pro's fingerprint sensor is paired to the board. If you replace it, you must pair the new fingerprint sensor to the phone using Google's official Pixel Repair Tool.
  • Note: The fingerprint sensor assembly is very thin and glued to the display assembly; if you are scavenging a fingerprint sensor from a donor device, soften the adhesive with heat or alcohol and peel the assembly off of the display, do not try to pull/rip it off with force as you may destroy the cable.
Pixel Repair Tool
