GameCube Controller
Jump to navigation
Jump to search
The Gamecube controller can often take a lot of stress on the motherboard. It's not uncommon to find the motherboard to be cracked inside. Be careful when taking apart the controller and inspect the frontside of the motherboard for cracks. Usually it cracks between the Start and B buttons. If the motherboard is cracked, it can break VERY easily under minimal force. (Don't ask me how I know)
You can easily test gamecube controller buttons with this Wii Homebrew software https://wiibrew.org/wiki/Visual_Controller_Test
Pinout/Motherboard scans https://simplecontrollers.bigcartel.com/sammy-controller-protocol https://imgur.com/gallery/F9DRE
Issue | Solution |
Controller shuts off the console | The wire is most likely broken shorting 2 wires together |
No input at all/No Power | Check to make sure the wire isn't broken, check to make sure the motherboard isn't cracked. Check for shorted capacitors. Try reflowing the CNT-DOL IC. Try replacing the CNT-DOL IC if no other issues were found |
Buttons don't respond | Inspect the motherboard for cracks. Clean buttons contacts and the rubber pad with IPA |
Analog/C stick drift | Clean/replace potentiometer or replace the whole joystick |
Controller won't vibrate | Check to make sure the wire to the motor aren't broken/soldered on correctly. Replace motor if necessary |
Cracked Motherboard | Carefully apply a small amount of superglue to hold the board together, after it dries scratch away each broken trace and reconnect with jumper wire |
