Guidelines
(Redirected from FAQ & Guidelines)
Welcome![edit | edit source]
You found your way to the Repair Wiki! A wiki where we collect everyone's findings on repairing electronic devices, so it's all in one place.
Page Structure[edit | edit source]
Pages are generally structured by section headers, and a table of contents that lets the user quickly find the section they're looking for. When you create new pages or edit existing ones, try keeping the general layout the same, namely:
  • Product / Guide Introduction
  • Main Problem Table for the product
    • example format:
Problem Solution
Problem1
Solution1
Problem2
Solution2
  • Links to references / other guides on the wiki.
New Page[edit | edit source]
Write as much or as little as you want, as it's stress free: if you don't finish, insert {{Stub}} at the top of the page.
Once you are finished, underline every single link you clicked through on each page to let people know where it's located and that it has information on it - the underline separates that page out from the rest to find easily.
Format[edit | edit source]
The title includes all the device information from just the title alone. This not only prevents title duplication, but also lets readers know what it is and where it's located at.
Steps:
1) write in all the link titles that came before it in order of the navigation.
2) Be sure to label the link after writing it.
Example: "Lenovo" should have "Laptops" after it, so it's known it's a laptop, not another device. "ThinkPad" would have "Series" after it, so we understand that too.
3) add model number last
Example: the T series has T410, so the T in the 410 stays, even though it's labeled T series before it, as that's the model number.
Overall the examples put together look like this: Lenovo Laptops ThinkPad Series T Series T410
Create:[edit | edit source]
  • enter the article title in the box (or on the homepage) to create a page with a preselected boilerplate.
  • type https://repair.wiki/w/ as a url in the url box of your web browser. Enter the name of your page after the w/. If there're multiple words, separate them with an underscore (i.e. _). Be use to use the appropriate case (i.e. upper and lower case), as it's case-sensitive.
Move[edit | edit source]
If a page has an incorrect title, you can move it:
  1. Mouseover the More tab in the top right and click Move.
  2. Give the page a New title and click Move page.
  3. For normal pages, don't change the default namespace (Main).
  4. Note that if you move a category page, pages belonging to it will need to be recategorized manually.
Delete[edit | edit source]
Other options:[edit | edit source]
  • If you don't want to have it truly deleted (to come back later to work on or archive it), or can't wait, then give the page a title that's not in use nor will be found. Just be sure to add the link of the page in the discussion tab of the place it got moved from, so people know it's still there if it was decided on being moved.
  • You can also add it to the Stub category by inserting {{Stub}} at the top of the page too for the off-chance someone else can grow it. Visit Stub Pages to help out those with the most need of contribution.
Minor changes[edit | edit source]
Table of Contents[edit | edit source]
Section level headers[edit | edit source]
From the Edit Source tab:[edit | edit source]
Section headers are added by using equal signs. Each indentation to a new level gets an extra equals sign surrounding the name (i.e. Level 2 gets 2 equals signs on each side, Level 3 gets 3, etc.).
Level 1 headers are reserved for the title and should not be used (i.e. =Example=).
==Level 2 header==
===Level 3 header===
Text
From the Edit tab:[edit | edit source]
Major Changes[edit | edit source]
Categories[edit | edit source]
Source Editor[edit | edit source]
Visual Editor[edit | edit source]
Hierarchy[edit | edit source]
The standard category format is [[Category:Brand_Product Type]].
Only add one or two categories per page, and make sure a relevant category doesn't already exist before you create new ones.
All product type categories should be a subcategory of Category:Product Repair Guides.
Say you're making a repair guide for the new MacBook Pro, you'll want to add the article to the [[Category:Apple Laptops]] category.
But since Apple has many lines / series of laptops, you'll want to specify further by adding the [[Category:MacBook Pro]] category as well.
If a brand does not have a wide product stack, further categorization is not necessary.
If your article applies to more than one or few products, it likely belongs in Category:Board Repair Guides.
If it's even more general than that, it belongs in Category:General Repair Guides.
Notes:[edit | edit source]
  • Once you save a category, changing it becomes cumbersome, so make sure you get it right. New subcategories can be added however.
  • Often a category will have a separate gateway article with links to specific products. Check the URL to make sure you're on the right page.
    • If a link to your page doesn't show up, try clearing the cache:
MediaWiki[edit | edit source]
This wiki uses MediaWiki Formatting, which is also used on Wikipedia. (Also known as Wikitext - there's a link to general help about MediaWiki / Formatting in the sidebar.).
Page Formatting[edit | edit source]
Links & Citations[edit | edit source]
Internal Links (Repair Wiki)[edit | edit source]
[[Main Page]]
[[Standards|Standards page]]
Result:[edit | edit source]
Main Page
Standards page
If the link is red, either the link is wrong, or the page doesn't exist yet.
However if you want a page to redirect to another page, you can use the following:
#REDIRECT [[Target Page]]
External Links (other websites)[edit | edit source]
Consider archiving your links to avoid link rot.
[https://www.gofundme.com/f/lets-get-right-to-repair-passed Right to Repair fundraiser]
After highlighting the text to use, use the hyperlink symbol or CTRL + K to add a link.
To transform an external link into a citation, enclose it in <ref>URL</ref> tags:
Donate to the GoFundMe<ref>https://www.gofundme.com/f/lets-get-right-to-repair-passed Right to Repair fundraiser</ref>
If you want control over where the references list appears on the page use:
{{Reflist}}
Donate to the GoFundMe[1]
Italic & Bold Font[edit | edit source]
Don't be scared to use bolded text frequently in your articles, such as highlighting crucial steps of the repair process or safety warnings. It helps the reader find what they're looking for faster.
Source Editor:[edit | edit source]
* ''italic text''
* '''bold text'''
** '''''bold italic text'''''
  • italic text
  • bold text
    • bold italic text
Line breaks[edit | edit source]
line break arrow
Arrows in the editor indicate a single line break. Characters following line breaks will be inserted on the next line.
You can add them in the source editor by typing <br>
Put line breaks on a new line, so people know they're there.
Use {{clear}} for line breaking all elements, including images.
Tables[edit | edit source]
To add a classic Problem & Solution table, fill in the template named "ProblemTable" or copy / paste the following into the source editor:
{{ProblemTable
|P1=Problem1
|S1=*Solution1
*Additional Solutions
|P2=Problem2
|S2=*Solution2
Problem Solution
Problem1
  • Solution1
  • Additional Solutions
Problem2
  • Solution2
To add a new row, simply define as many |P1 and |S1 parameters as needed.
In-line Tabs[edit | edit source]
Source editor, for 3 tabs:
{{#tag:tabber|
Tab 1=
one
Tab 2=
two
Tab 3=
three
Results:[edit | edit source]
one
two
three
Uploading & Embedding Files[edit | edit source]
Click Upload File in the sidebar to upload files.
Once uploaded, insert either of the following at the top of the page:
{{File|FileName.png|Fig. 1: File Caption}} or [[File:FileName.png|right|thumb|350px|<center>'''Fig. 1: File Caption'''</center>]]
Example:[edit | edit source]
Fig. 1: Rossmann Group logo
Make sure to reference the image in the solution text, ie. "See Fig. 1".
You can search for images in the public domain here.
Templates[edit | edit source]
You can create your own template or find what's already created here Category:Formatting templates. Boilerplate templates are portions of information that get copied/pasted. If you edit the original, all the copies will change accordingly.
Transclusion[edit | edit source]
You can include a page inside another page with {{:Page name}}.
Make sure to use <onlyinclude>text</onlyinclude> to not duplicate too much content (search engines don't like it).
Note:[edit | edit source]
Make sure the page or Template you're transcluding has its categories inside noinclude tags: <noinclude>[[Category:IPhone]]</noinclude>
if you want to link to a category instead, colon symbol in front of it: [[:Category:Product Repair Guides]]
Code text:[edit | edit source]
A highlighted blue box around text that's inside it.
Source editor: type in <code>highlight word</code>
highlight word
Visual editor: copy/paste from text that already has it.
Warning:[edit | edit source]
Watch out for writing before and after the box, because they might get mixed into the box itself, when it shouldn't.
Suggestions[edit | edit source]
If you have suggestions for how to improve the wiki, you can leave them on Talk:Repair Wiki
Talk Pages / Discussion[edit | edit source]
Every page has a Talk Page associated with it.
Click on Discussion in the top left to leave a comment on it, then add ~~~~ to insert a user signature, like so: Patrolin (talk) 15:21, 24 April 2021 (PDT)
It is probably easier to just use the Discord, but it's a good use for leaving notice board-like notes.
Responses[edit | edit source]
When responding to someone in the talk pages, do it on a new line and prefix your message with : to give it indentation.
This is the OP speaking. Patrolin (talk) 02:43, 5 May 2021 (PDT)
This is a response to OP. Karar (talk) 02:57, 5 May 2021 (PDT)
Here I've used double colon punctuation :: to respond to the message above. Patrolin (talk) 03:00, 5 May 2021 (PDT)
Another response to OP. Karar (talk) 02:57, 5 May 2021 (PDT)
Louis Rossmann's Repair Video Project[edit | edit source]
A project is underway to transfer information from all of Louis Rossmann's repair videos onto this wiki.
To avoid duplicating effort, we are using Google Sheets. Please mark videos as 'Done' when you have added their contents to the wiki, or confirmed that they are already on the wiki.
Searching through captions[edit | edit source]
You can find captions by video URL here
Ctrl+F and paste the part of the URL after v=. For example: QnowcxcO2-0
Viewing schematics and boardviews[edit | edit source]
Your work[edit | edit source]
  • Mentioning copyrighted materials is at times unavoidable; sometimes someone already wrote out the solution or the reader wants more detail. Refer to the "Links & Citations" section under the "Formatting" tab to properly cite others' work.
  • If you make a new page or category on the Repair Wiki, you don't need to ask anyone for permission. You can even give yourself or someone else credit by inserting {{Credit|Name}}
  • All content on the Repair Wiki is for public use. You can freely download pages for your own use or for sharing with others using Special:Export.
Proprietary Material[edit | edit source]
  • Examples: patented schematics, instruction manual PDFs, other people's images, plagiarized problems/solutions from online articles etc.
  • Material that is not your own or available for use under laws (such as fair use), licenses (i.e. open source), and copyrights (like public domain or creative commons) shouldn't be posted without permission. If permission is granted, then that should be stated next to the proprietary material, so that it's made known and can be verified by the grantor.
  • Anything that puts (or is at risk of putting) the Repair Wiki at risk of being litigated against and taken down shouldn't be posted.
