DualShock 4
Jump to navigation
Jump to search
Controller not connecting/charging through USB[edit | edit source]
- Check USB port
- if controller has been opened, check ribbon cable/connector for damages
- check for open fuse (charging) / shorted USB data (D+/D-) protection component (communication) on USB-connector board
Problem | Solution |
Taking 1.4 amps instead of 0.5 amps |
Taking 3.4 amps or more rather than 3 amps |
Not Charging. |
Drifting analog sticks[edit | edit source]
Controller analog drift (move by itself in-game) |
Controller pushes buttons by itself. |
D Pad buttons or other buttons on the face of the controller stop working Only certain controller buttons are working |
Often caused by issues with the conductive film the buttons contact
