Clevo P570WM
The Clevo P570WM is an interesting desktop-replacement tier Clevo laptop. There are a few rebrands of it: it is the same as the Eurocom Panther 5D and the Sager NP9570. It runs 4th gen Intel desktop processors, up to an i7-4960X. It has dual MXM slots for SLI linking two graphics cards. In SLI, it can run up to two GTX980Ms, or if you just are using a single card, it can run a GTX1060M. Max RAM of 32GB, 5HDD slots, 17.3" screen, all the goodies. You can do a lot with this computer. Most replacement parts are easy to find and cheap to source, with a few exceptions. For exact part number compatibility, you should cross-reference this manufacturer listing for the computer.
The hardest parts to find replacements for with this computer are the heatsinks and the fans, although they are available OEM. Other than that, most of the components are standard and you can easily find them on Ebay.
Compatible Non-OEM Parts[edit | edit source]
These lists are just for posterity in the case the original manufacturer site were to go down. This is just a copy of the "upgrade lists" they provide- they are all fully compatible parts. For parts not on here, you will have to buy them from Clevo/Eurocom or find the specific part on eBay, these are the only "optioned" parts.
GPU 1[edit | edit source]
  • NVIDIA GeForce GTX 670MX; 3GB DDR5; MXM 3.0b; 75W
  • NVIDIA GeForce GTX 680M; 4GB DDR5; MXM 3.0b; 100W
  • NVIDIA GeForce GTX 780M; 4GB DDR5; MXM 3.0b; 100W
  • NVIDIA GeForce GTX 770M; 3GB DDR5; MXM 3.0b; 75W
  • NVIDIA GeForce GTX 880M; 8GB DDR5; MXM 3.0b; 100W
  • NVIDIA GeForce GTX 980M; 8GB DDR5; MXM 3.0b; 100W
  • NVIDIA GeForce GTX 970M; 6GB DDR5; MXM 3.0b; 80W
  • 6GB GDDR5; NVIDIA GTX 1060; 1280 CUDA; N17E-G1; 82x105mm; MXM 3.1
  • Quadro P5000; 16GB GDDR5; N17E-Q5; 2048 CUDA; MXM 3.1b; 82x105mm; 100W
  • 6GB GDDR5; NVIDIA Quadro P3000 (N17E-Q1); 1280 CUDA; OpenGL; MXM 3.1; 16nm; 75W
  • NVIDIA 4GB GDDR5; NVIDIA Quadro K3100M (N15E-Q1); MXM 3.0b; 75W
  • NVIDIA 8GB GDDR5; NVIDIA Quadro K5100M (N15E-Q5); MXM 3.0b; 100W
  • 4GB DDR5; AMD Radeon R9-M290X; MXM 3.0b; 100W
GPU 2[edit | edit source]
  • 8GB DDR5; NVIDIA GTX 980M; NON-G-SYNC; MXM 3.0b; 100W
  • 16GB GDDR5; NVIDIA Quadro P5000 (N17E-Q5); 2048 CUDA; OpenGL; MXM 3.1; 100W
  • AMD Radeon R9-M290X; 4GB DDR5; MXM 3.0b; 100W===
WLAN Cards[edit | edit source]
  • 2-in-1; 802.11 ac/a/b/g/n + Bluetooth 4.0;Intel Dual Band Wireless-AC 7260; 7260HMW
  • 2-in-1; 802.11b/g/n WLAN + Bluetooth 4.0; up to 300Mbp/s; Bigfoot Killer Wireless-N 1202; Atheros AR5B22
Displays[edit | edit source]
  • 17.3in; FHD; 60Hz; Glossy (GT); LVDS; Hannstar HSD173PUW1
  • 17.3in; ; FHD 60Hz; Glossy (GT); 90% NTSC; AUO B173HW01 V.4; 500:1; LVDS
  • 17.3in; FHD; 60Hz; Matte; IPS; LVDS; Chimei N173HGE-L11
  • 17.3in; FHD; 120Hz; Matte; eDP; LP173WF2
Optical Drive[edit | edit source]
  • 8x Multi DVD +-RW/-RAM Burner; Dual Layer; Tray Load; SATA
  • 6x Blu-Ray WRITER; Tray; SATA; Pioneer BDR-TD05; BD-R XL; 100/128GB; 12.5mm
Drivers[edit | edit source]
Clevo provides a suite of drivers that are supposed to work out of the box. In my experience I have gotten them all to work with an exception for Bluetooth and 980M SLI (SLI with other MXM combinations worked fine). You can find the drivers here.
Operation and Service Manuals[edit | edit source]
The both of these manuals can easily be found online, with the service manual including component level drawings and schematics as well as general troubleshooting tips.
Here is the operators manual, direct from Clevo.
Here is the service manual, direct from Eurocom.
