Bitmain S19 Hashboard
Introduce the product / guide here.
Repair Tips for the BitMain S19 hashboard for cryptocurrency mining[edit | edit source]
Problem | Solution |
Reading 0 ASIC |
Unlike every other signal on the board the RO signal is sent from chip 76 to chip 1. To find the bad chip the fastest you should check chip number 38. The reason you check this one first is if you get an RO signal on chip 38 you can rule out the issue to between chip 1 and chip 37. next you divide the board again and check chip 19. For our example we'll say that chip is reading 1.790 volts. That is still within acceptable limits. so we have ruled it down to chip 1 through chip 18. Now we check chip 9 and find the RO signal is 1.3 volts. That is not a good voltage. Now that we have a good stopping point going down, we now nned to go in reverse because we know the bad chip is between 9 and 18. Lets check chip 13, and when we do we can see its showing 1.8 volts coming out. Go ahead and check chip 14. now on 14 we see the signal drops to 1.6 volts. Before you get to soldering make sure double check your voltages and when you determine the faulty chip there are a few options. Sometimes you can flux and reflow the chip using light pressure on top of the chip with tweezers to ensure it is seated properly, and if that doesn't work you can replace the chip. in our example chip 14 is the faulty chip. |
Reading X Asic |
