AtlasIED BBWP-Touch7
The AtlasIED BBWP-Touch7 is a 7" touchscreen interface for controlling BlueBridge DSP systems manufactured by AtlasIED (Atlas Sound) .
This device is an industrial class Android device which receives power via PoE or a local DC power supply.
Failure on these devices is rare so it's important to first identify that there actually is something wrong with the hardware and not that it's simply misconfigured.
Configuration, firmware updates and some analysis is performed via BlueBridge Designer software that can be downloaded from the manufacturer's website.
Note that units manufactured after July 2021 do not use a MicroSD card system disk.
Most Common Faults[edit | edit source]
Problem | Solution |
Black Screen, no backlight, no apparent activity when given PoE or local DC power |
White Screen, or Black but it is obvious backlight is illuminated. |
