Asus S301LA
Jump to navigation
Jump to search
Asus S301LA onboard RAM disable[edit | edit source]
Problem | Solution |
Disabling onboard RAM for Asus S301LA |
I used S301LA Rev: 2.2 boardview for this guide. We need this mod when suspect about onboard RAM chips. All onboard RAM chips must be removed. If client requires the onboard RAM, replace the RAM chips and shift back the resistors.
This will list all RAM configuration lines, DIMM_SEL1-3. Initial RAM configuration is 000; RAM slot plus onboard RAM available. See Fig.1.
Shift R2119 to R2160. See Fig. 2.
Shift R2120 to R2161. See Fig. 3.
Shift R2121 to R2162. See Fig. 4.
