A1502 2013-2014 13” MacBook Pro Retina
Problem Solution
Random crashing If bad SSD, bad SSD. If not bad SSD... no answer.
Not turning on, power button not working Ribbon connector to keyboard bend/dirty/broken (bend back/clean/replace)
Example: https://www.youtube.com/watch?v=QnowcxcO2-0 (second repair, ribbon connector bend/dirty)
No power, PPBUS_G3H 4 V instead of 12.56 V U7100 ISL6259 bad, shorted current sense resistors R7121 and R7122 to ground through the U7100.
No power. Major corrosion around U7100 (ISL6259) area. U7100 area and Thunderbolt T29 Boost Regular cleared, corrosion removed and replaced. Video Source: https://www.youtube.com/watch?v=EV1t85Q8vqM
No power, 24–25 mA current draw
  • PM_SLP_S4_L missing for random reason, thoroughly inspect clock chip, tiny specks of corrosion next to it can kill it. Sometimes shotgun replacement of the chip is a clean solution.
  • Bad U1900 clock chip
  • Bad right I/O board. Unplug it, see if it works (short on 3.3 V or 5 V rail on the I/O board can cause this problem).
No power, 180 mA taken Corrosion at U1950
Example: https://www.youtube.com/watch?v=X2UlXmMMn6Y (replaced U1950, capacitor and resistor)
No green light on charger
  • ADAPTER_SENSE not 3 V due to bad DC in board. 16–20 V on ADAPTER_SENSE means charger voltage is leaking into ADAPTER_SENSE, below 2 V means it is missing usually due to a bad DC in board.
  • PP3V42_G3H missing
  • SMC not working(if SMC is off, you will have 12.23 V on PPBUS_G3H instead of 12.56 V) because it is dead, not turning on (SMC_RESET_L low).
Example: https://www.youtube.com/watch?v=FlaUiYB9FbM (U5110 (chip responsible for SMC_RESET_L) not working)
  • Corrosion of the SMC solder connections
Example: https://www.youtube.com/watch?v=YUPH7Vaama4
  • Keyboard bad, shorting PP3V42_G3H to ground or power button stuck on.
  • Bad U7000/U7001.
Battery not recognized First, try a known good battery.
If it doesn't work, check PPBUS_G3H. If it is 12.23 V, the SMC is not communicating with the battery on its data line, either because the SMC is bad, or because the pull-up resistors on the data line are bad. On rare occasion U7100 can pull down the data lines. There is a shared data line between the battery, SMC, and ISL6259(U7100). If PPBUS_G3H is 12.56 V, then you probably have a bad battery.
No backlight Make sure the issue is no backlight, and not no image!
  • Short to ground on backlight output (if backlight fuse blown, check this).
  • Trace of backlight output interrupted (can be caused by corrosion, can be fixed with jumper wire)
Example: https://www.youtube.com/watch?v=O0_0YtdwgF0 (Repaired all corrosion including: LED driver replaced, SMC reflow, Thunderbolt chip replaced, screen connector cleaned and connections resoldered, several corroded components in memory area and screen power area replaced, jumper wire for screen backlight output)
  • Bad screen/screen cable. If backlight voltage is 49–50 V, bad screen.
  • USING WRONG SCREEN! If you use a 2012, or a 2015–2016 screen on a 2013–2014 A1502, IT WILL NOT WORK!
If the screen is shorting the backlight to ground, you can fix the screen if the capacitor/connector on the screen is bad, it just sucks to do. But it is the only option since this screen is no longer available.
You can fix the screen if the capacitor/connector on the screen is bad, it just sucks to do. But it is the only option since this screen is no longer available.
No image
  • Bad screen cable
  • Screen cable needs reseating (this fixes it a surprising amount of the time)
  • Blown L8300
  • Bad GPU inside the CPU.
When you find that 5 V is still missing on L8300 and LCD_PWR_EN is missing on U8300, do not chase. 99% of the time this turns out as a no fix, usually bad iGPU or MUX communication issues.
Running slow/fans high The machine running exceptionally slow with the fans spinning fast denotes a sensor issue. When a sensor is off, and it thinks the voltage/amperage is too high/low somewhere, or that the temperature is too high/low somewhere, it will clock the machine down and cause the fan to run at max RPM. You have to use a tool that reads sensors like hwsensors, or boot into a Linux distribution to check your sensors, then chase down the circuit responsible for that sensor using the schematic/boardview. If all sensors are off, this usually points to an issue with the SMC or PP3V3_S5_AVREF_SMC.
  • Bad trackpad can cause sensor issue. Water gets to the trackpad first in many occasions.
  • Q5871 corroded, difficult to see without microscope, on edge of board.
  • U5870 corroded, on edge of board next to fan where water comes in.
19.5 V 100–200 mA on charger As usual check PPBUS_G3HOT, PPVRTC_G3H, PP5V_S5
PP5V_S4 is 0 V (problem here)
C7320 has corroded pad so U7320 had no input on pin 6 so no Vcore was being produced on one of the power phases.
Redoing the corroded trace with a jumper wire and replacing the U7320 chip solved the problem.
Video: https://www.youtube.com/watch?v=8s7HBtQYcaM
18.5 V 150–200 mA on charger
No keyboard backlight
On this video the keyboard backlight connector is destroyed https://www.youtube.com/watch?v=PCJfa73GFOU
variable current and intermittent fan spin, 820-3476
Corrosion in U1950 area and corrosion at JTAG connector.
On this video the U1950 chip was replaced and a jumper wire ran, JTAG connector bulldozed off board. U1950 allows other signals and power rails to turn on the computer. Example: https://www.youtube.com/watch?v=yGDURMxwzt8
Will not run off of a known good battery, but can see the battery and identify its health within the operating system using coconutbattery Check R7005. If blown, PP3V42_G3H will not be present when running off the battery, but will be present when running off the charger.
80 mA, machine does not turn on. Corrosion at U1900 RTC (Real Time Clock) circuit
Green light on charger, fan runs full speed, machine does not turn on. Measure voltage on inductor L7310 (CPUVR_PHASE1) located just to the left of the CPU. Should be 1.85–1.95 V
If voltage is missing check for corrosion on other side of the board (in the location where the CPU is positioned but on the back of the board) around C1212. Some capacitors including C1212 could be shorted to ground but that isn't the cause of the fault. Clean up the corrosion first. Check for hot parts using voltage injection and a finger.
In this case it was U8030 TPS22924 3.3 V S0 switch that was shorted and removing the part cleared the short. Replace with good part, problem solved. Example video for this repair: https://www.youtube.com/watch?v=C9Qb32XtROE
Note this repair also applies to the A1502 2015 model but the parts will probably have different U locations.
No power, cycling between 20–60 mA. Rails from S5 to PP1V5_S0 pulsing. Short on PP5V_S0_AUDIO_AMP_R (C6422 on 820-3476). PP5V_S4 reads shorted as it is connected to PP5V_S0 via 5 V S0 switch.
USB ports not detecting drives For left port on logic board check for 5 V at L4605. If low or non existent check for PP5V_S4 at pins 2 and 3 of U4600. If that VIN is OK check for USB_PWR_EN at pin 4. If that is low try removing U4600 and rechecking USB_PWR_EN. If it comes back up to ≈3.3 V then replace U4600 and recheck for 5 V at L4605. This obviously doesn't cover all possible scenarios but it is one.
