A1387 IPhone 4s
A1387 iPhone 4S[edit | edit source]
Release date: October 14, 2011
Screen size: 3.5 inches
Screen Resolution: 640x960
Memory: 512 MB DDR2 RAM
GPU: PowerVR SGX543MP2
Battery: 3.7 V, 5.3 Whr (~1430 mAh) Lithium-ion battery
PROBLEM MOST LIKELY REASON FIX
SHORT BATTERY LIFE
(instant death, irregular charge time, ect.)
BAD BATTERY To replace iPhone 4s,
- Remove the two P2 Screws at the bottom of the phone
- push the back glass up towards the top of the phone. pull off glass gently.
- remove the two Philips 00 screws holding the battery connector on, (pay attention to placement of these screws)
- carefully remove pressure contact
- unclip battery connector
- pull battery tag ( if no tag, use 99% alcohol under the battery)
place new battery, reassemble
Credit[edit source]
Original article credit: Dan Bullock
