3190 2 in 1
Jump to navigation
Jump to search
The Dell Latitude 3190 was an improved release of the 3189, with a quad core Pentium processor, produced primarily for K12 applications.
In the coming days I will populate this page with simple fixes to the most common issues I have experienced. This page is a work in progress, started June 14th, 2021.
- Not powering on, or appears to not charge
- (Internal MB cable loose, will add pics)
- Left hinge failure, the brass heatserts break out of the chassis. Preventative measures best, if it gets wiggly then tighten the screws.
- SSD is serviceable
- Wireless NIC failure is not serviceable
- Intel SSDs are notorious for failure
- M.2 is SATA only
- Keyboard model, cheap to replace.
- Audio daughter board separate module, can be replaced if broken
- LCD assembly kit link
- Track pad ribbon cable not seated properly
- How to determine if it is the charger or battery, battery communication in BIOS
- HP chargers will likely not work, must use Dell branded chargers. Use knockoffs at your own peril.
- DC socket insulating barrel will disappear in a 2018 production batch. VERY common. If this happens, the socket can short out and (I presume) damage the charging circuit. Replacing the socket itself will not fix this.
- All parts except the audio daughter board are interchangeable with the 3189. You can still make the daughter board work, though.
Error light codes, common one is 3, 5
LED FLASH SEQUENCE | FAULT DESCRIPTION | FAULT(S) |
2,1 | CPU | Possible CPU Failure |
2,2 | Motherboard BIOS | Motherboard, Covers BIOS Corruption or ROM Error |
2,3 | Memory | No memory / RAM detected |
2,4 | Memory | Memory / RAM failure |
2,5 | Memory | Invalid Memory Installed |
2,6 | Motherboard Chipset | Motherboard / Chipset Error |
2,7 | LCD | LCD Failure |
2,8 | LCD | LCD Power Rail Failure |
3,1 | RTC Power Failure | CMOS Battery Failure |
3,2 | PCI / Video | PCI or Video Card / Chip Failure |
3,3 | BIOS Recovery 1 | Recovery Image Not Found |
3,4 | BIOS Recovery 2 | Recovery Image Found But Invalid |
3,5 | Power Rail Failure | EC ran into power sequencing failure |
3,6 | SBIOS Flash Corruption | Flash corruption detected by SBIOS |
3,7 | ME Error | Timeout waiting on ME to reply to HECI |
https://www.dell.com/support/kbdoc/en-us/000127927/a-reference-guide-for-latitude-notebook-and-tablet-diagnostic-indicators
