1.8V Rail on Pascal GPUs
This page explains how the 1.8V rail is created and what it is used for in Nvidia Pascal GPUs and the most common problems that could occur.
The Controller Circuit[edit | edit source]
For GTX 1070s, 1080s, and 1070 Tis the IC responsible for creating the 1.8V rail is typically an MP1475, but an RT7296F is sometimes used in its place. While on GTX 1080 Tis and other GP102 based cards, you would typically expect to see an AOZ1267QI-01 as linked here
The RT7296F is a Synchronous Step-Down Converter made by RICHTEK. You can find the datasheet Here and it's the same one used for the 5V Rail on Pascal GPUs.
MP1475's datasheet can be found here
the workings of this controller is detailed on the 5V Rail on Pascal GPUs page, the difference is that this one gets its EN signal from the PG pin of the 5V controller.
Usage[edit | edit source]
On Pascal family of GPUs, 1.8V is used to power low level logic in the GPU core itself and in most situations the BIOS chip as well
Common Problems[edit | edit source]
No voltage out on the 1.8V rail[edit | edit source]
First thing to check is the EN signal which should be 2V+ followed by Vin which should be 12V (Figure 2) if one of them is missing then check the schematic and follow the signal to find the culprit, it's usually a faulty resistor.
EN signal comes from the 5V Rail Controller. if you don't have it then check the 5V Controller.
After making sure both of the above are there, check the VCC pin. If there is no 5V on it then most likely the controller is faulty and needs changing. If there is 5V on VCC, check out the resistor divider and make sure their values are the same as in the schematic (Figure 2).
Short Or Low Resistance[edit | edit source]
The 1.8V rail goes straight to the core, if you have low resistance or it's shorted then most likely you have a dead GPU on your hands. A short on 1.8V is accompanied by a dead core well over 95% of the time.
If you're very lucky, the problem could be coming from the BIOS chip, start by removing it and checking if the short is still there. In the case that the 1.8V short didn't go away, you could check the capacitors that are associated with it, Shown below on figure 5.
If you have access to a thermal camera, it is extremely easy to tell if the core is the source of your short. On Nvidia GPUs, the "1.8V" portion of the GPU is typically in the bottom left corner, and as a result shorts on the 1.8V rail often look similar to the images below.
No PowerGOOD Signal[edit | edit source]
PG signal from the controller is the same signal that enables the Vcore rail, if the buck converter doesn't form that signal the rest of the card won't work. The most likely cause is the controller itself. If 1.8V is being outputted, however, if even after replacing the controller you still don't have PG then check the FB circuit (Figure 2) and make sure every resistor is the right resistance.
